Old 12-17-2009, 08:22 AM   #1
1993 34' Excella
Whitehouse , Texas
Frayed Emergency Brake Cable
I just bought a '93 Excella, and yesterday I discovered that the end of the emergency brake cable is frayed. What type of replacement cable do I need?
Erica.Gish is offline   Reply With Quote
Old 12-17-2009, 08:32 AM   #2
Images: 59
Disconnect the battery, pull the pin and take the cable to a hardware store. They should be able to match the diameter of the cable, cut off the old loop, rethread the pin and crimp on new sleeves. Shouldn't cost more than $6.
Old 12-17-2009, 02:13 PM   #3
Kevin245's Avatar
Had the folks at the local Lowe's make mine up. Less than $5.00 if I recall correctly.
Kevin
Eleanor Roosevelt
Old 12-17-2009, 02:45 PM   #4
Break away switch cble
Replacing the cable is OK.
Just make "SUPER POSITIVE" that the loops in the cable, cannot possibly become undone.
If that happens, the breakaway switch pin will never pull.
Old 12-17-2009, 03:39 PM   #5
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I would, like Andy say's, REPLACE the cable. Cable and clamps should be available at your local Ace Hardware or at Lowe's. Like Mark says shouldn't be more that 5 or 6 bucks. I kinda found myself in that position on returning from a trip this summer and finding that the cable had been dragged in two. I squared the ends and cut the cable to the appropriate length(it was always to long) and slid on a connector and closed it with my railroad iron and a hammer. While there I also detected two open links in the safety chains and replace them also."SAFETY IS NO JOKE"
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 12-17-2009, 04:16 PM   #6
Images: 59
The breakaway cable and chains should certainly be on your pre-trip inspection.
Hook Emergency Break-away cable to what? OB Bambi Brakes & Brake Controllers 16 08-18-2011 03:35 PM
Emergency Trailer Brake Quit Working AustinAir Brakes & Brake Controllers 3 01-17-2009 08:23 AM
Emergency help needed! markdoane Batteries, Univolts, Converters & Inverters 10 06-22-2007 08:11 PM
frayed not gryphon Upholstery, Blinds, Walls & Interior Finishes 13 03-14-2004 12:15 PM
3 musings (refrig, brake controller, emergency supplies) casarodante Our Community 2 04-02-2003 11:23 AM
