Old 07-28-2007, 10:10 AM   #1
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Ford Brake Controller
Built-in on the newer Ford trucks. Anyone had good or bad experiences with them? We haven't been out much since we got this F250 so am just checking to see if there is anything we might need to be aware of. Thanks
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 07-28-2007, 10:18 AM   #2
ScottW's Avatar
Hernando , Mississippi
Jaxon,
As I recall, the owners manual on my 07 Classic specifically lists 4-5, maybe six controllers recommended for the new disc brakes (if you have them). I'm certain the Ford OEM controller is one of them. Can anyone support this? I'll look it up later and get back with another post if needed.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 07-28-2007, 10:28 AM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I would also appreciate input on this. I will need to upgrade from my F150 as a result of the step up to the ’34’ trailer. Any additional information will be helpful.
Vaughan
Old 07-28-2007, 10:32 AM   #4
ScottW's Avatar
I installed a prodigy controller in the dashboard hole where the OEM controller would normally be. Found the following on activetech web site...
"Approved In-Cab Brake Controllers
The inertia based brake controllers which Active Technology approves for use with the ActiBrake are:
Hayes Genesis, Hayes Energize XPC, Hayes Endeavor, Hayes Energize III and Tekonsha Prodigy and the Ford Super Duty in-dash brake controller. The
ActiBrake may work with other controllers, but the operation of the ActiBrake and trailer braking
performance may NOTbe optimized. (ABRAKE SYSTEMS OPERTIONALQUALITYCAN BE NO
BETTER THAN THE OPERTIONALQUALITYOF THE IN-CAB CONTROLLER!) ".
Now, having contradicted myself...I saw the Ford controller specifically mentioned as OK. Give me a while to find the reference.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Old 07-28-2007, 10:39 AM   #5
ScottW's Avatar
OK...sorry for the delay. In case you read the above posting before I added the italicized info, please read again. The original was copied from the web site. The italics was just read in the Owners manual from Active Technology that came with my 07 Classic. If they say the Ford controller is OK...then it should work as well as my Prodigy - and It works GREAT!. Hope this helps.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Old 07-28-2007, 11:04 AM   #6
2007 25' Safari FB SE
Suburbia , Sunny So Cal
The Ford brake controller works great!
It is compatible with both disc brake controllers.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 07-28-2007, 01:01 PM   #7
E Pluribus Aluminus
Jaxon's Avatar
1967 22' Safari
2005 30' Classic
Rockport , Texas
Good news. Thanks y'all. Seems to have been OK for relatively "local" trips... just kind of wondering about longer distances over time. New product and double nice that it's OEM.
Bill & Kim
Old 07-28-2007, 02:59 PM   #8
CanoeStream's Avatar
St. Cloud , Minnesota
There are plenty of good discussions if you search the forums on towcommand (all one word).
5 meter Langford Nahanni
Old 07-28-2007, 06:34 PM   #9
dpandorf's Avatar
2000 34' Limited
Somewhere in Western , North Carolina
F450 & Brake controller
Here's a link to a group that have driven a new '08 Ford F450 a 150,000 miles in 131 days pulling at a minimum a 12,000 pound trailer and for 100,000 miles an 18,000 pound trailer.
Duane Pandorf
Blog | Google+
Air# 16888 | 2000 34' Limited | 2008 Ford F250
dpandorf is offline   Reply With Quote
Old 07-28-2007, 06:52 PM   #10
_
hi jaxon
do you have disc brakes or drums on your classic?
as c'stream has suggested search with towcommand and 12 useful threads will appear....
several of us have posted relevant info already
if you've not towed with the combo yet, you'll need to...
-calibrate the amount of boost on the dash controller...
IF discs...
-run through the initial set up process for the actibrake/towcommand...
-then calibrate the amount of boost on teh dash controller
-assume the brake pads/rotors (on the trailer) haven't been properly bedded and do this too...
check the pads for thickness/wear after the setup is completed.
and consider changing the brake fluid with the next wheel bearing service...
cheers
2air'
Old 07-28-2007, 06:53 PM   #11
E Pluribus Aluminus
Jaxon's Avatar
1967 22' Safari
2005 30' Classic
Rockport , Texas
Duane,
I saw that one the other day - pretty nice truck... it's kind of what got me to thinking about the controller - Airstream-wise... Seems the manufacturer and dealerships always have better luck with the product than I do... dunno, not sure what that's all about...
Bill & Kim
Old 07-28-2007, 06:59 PM   #12
dpandorf's Avatar
2000 34' Limited
Duane,
I have the new '08 F250 with the brake controller and have pulled our 34' over 2000 miles so far and love it the brake controller/tow command package. The tow mirrors are a very nice option to boot too.
Duane Pandorf
Blog | Google+
Old 08-28-2007, 02:29 PM   #13
2006 30' Classic S/O
Mt Vernon , Texas
I just used my 2008 f-250 with my 06 Classic, did not seem to work as well as my other controler did. I also ge a disconnect light that comes on some time.
double/eagle is offline   Reply With Quote
Old 08-28-2007, 02:39 PM   #14
ScottW's Avatar
You might try some electrical contact cleaner on both TV and Classic. Then make sure the connector 'clicks' into position.
Been there!
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Jordan Research Ultima Brake Controller RoadKingMoe On The Road... 0 09-26-2002 12:41 PM
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 08:47 AM
Ok, I need a brake controller Chuck Brakes & Brake Controllers 6 06-07-2002 12:43 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
