Old 01-28-2016, 06:17 AM   #15
dznf0g's Avatar
Oswego , Illinois
Originally Posted by terryg View Post
FYI,
I have a 2008 Classic with the Actibrake electric/hydraulic setup. It works great with a Prodigy P3 or Direclink controller. However, my new 2015 Silverado 2500HD's integrated brake controller doesn't "see" the Actibrake setup at all.
Hmmm, something else going on, I think. I still have my (2nd design) original Actibrake, and it has worked fine on 2 different 2015 1500s. The 2500 system is identical on 2015 and forward as the 2014 and forward 1500s.
Is your Actibrake 1st design (recalled) or second design?
-Rich-
Old 01-28-2016, 05:31 PM   #16
2016 30' Classic
Sandpoint , Idaho
I didn't know there was a "second design". The unit currently in my trailer was installed by the dealer in Sep 08 after the original unit failed. It has worked perfectly since then. Recall 2010-07-28 stated "dealers will inspect the brake controller and if found to be defective it will be replaced ...". My dealer said mine was working fine and didn't need replaced so I assume I have a "1st design".
terryg is offline   Reply With Quote
Old 01-28-2016, 08:17 PM   #17
2016 30' Classic
Sandpoint , Idaho
Correction: I just reviewed the sticky and I have the version 2 Actibrake.
Brake controller for disc brakes dickschaak Hitches, Couplers & Balls 4 04-19-2009 05:27 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
Disc Brake Controller rrpranch Brakes & Brake Controllers 20 05-09-2007 11:25 PM
