Old 04-20-2006, 12:10 PM   #1
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
Question failed electrical connection on brakes on one side only
We took our new-to-us 1999 30' Excella to our favorite mechanic to get the brakes checked and bearings packed. He's an excellent mechanic, and has worked on big trailers/brakes before - although not Airstreams.
He said the brakes and bearings were fine, but the brakes were only activating one side - there was no electrical signal to the other side.
He's going to track down the problem, but I thought I'd see if I could get some quick advice to pass on to him as to where he might start.
So, what's the most likely place for a problem? (by the way, he says my plug doesn't fit as snugly into the back of my (new) TV as it should. I'm sure he'll look at that.)
Any suggestions?
Tin Diesel is offline   Reply With Quote
Old 04-20-2006, 12:16 PM   #2
Click here to read a thread which discusses this, and it also gives links to other relevant threads:
http://www.airforums.com/forum...gram-7467.html?
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 04-20-2006, 01:54 PM   #3
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
you have a broken wire going to that side
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 04-20-2006, 02:02 PM   #4
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
I found this two days ago while sanding in my wheel well getting ready to POR15 it....get under there and check things out!!...I to just had new tires put on and bearings re-packed and they missed this
enduroryda is offline   Reply With Quote
Amplified Antenna Connection smily Airstream Motorhome Forums 10 09-03-2005 03:25 PM
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
