Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 05-16-2013, 12:29 PM   #1
1986 29' Sovereign
Chanhassen , Minnesota
Factory GMC Brake Controller - OK as is?
Going to pick up a newly purchased 1986 Airstream. My first experiance pulling a large trailer. I recently bought a new 2012 GMC Yukon XL with HD trailering and the integrated trailer braking controller.
Does the factory controller work well with a trailer of this vintage?
Do I just plug in and adjust per the truck instructions. That easy?
What a rookie question!
Harrysheets is offline   Reply With Quote
Old 05-16-2013, 01:46 PM   #2
2000 30' Excella
Toledo , Ohio
I have a 2009 2500HD and a 1985 Sovereign and it should work fine .
Les Grace wbcci#14183
woodfox45 is offline   Reply With Quote
Old 05-16-2013, 01:57 PM   #3
rperrym's Avatar
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village , Arkansas
We have a 2013 GMC 3/4 Duramax with the integrated brake controller, and it works fine with our EB 25.
I had a Prodigy on the previous TV and I can't tell any difference.
Rick
rperrym is offline   Reply With Quote
Old 05-16-2013, 02:11 PM   #4
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Mine works fine on my '08 Sierra 2500 / DMax ... though to get power to it and to the trailer "charge line" I had to hook up a couple of wires to the fuse box under the hood. And the dealer was totally clueless. Had to actually go online and do a little searching to find out what to do. And the two studs to which the wires (once I found them) attached were different (and metric) sizes ... so it took a trip to the hardware store to get the proper nuts to attach them. I'm hoping that your newer machine came hooked up, but read your owner's manual CAREFULLY on this point.
AirsDream is offline   Reply With Quote
Old 05-16-2013, 02:30 PM   #5
1986 29' Sovereign
Thanks for the quick response!
Old 05-16-2013, 04:20 PM   #6
1988 32' Excella
Robbinsville , New Jersey
The power for your brake controller should be hooked up, but there are probably 2 loose wires under your hood 1 for an after market controller and 1 for the 12 volt supply line for charging the trailer. You probably need to hook up the loose wire for 12 volt power for the trailer.
Old 05-16-2013, 04:48 PM   #7
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Carefully read both manuals (truck and trailer), be sure you know what type of brakes you have - my 2013 Duramax works perfectly with my 2012 Flying Cloud's electric brakes, but the truck manual makes it CRYSTAL clear the controller will not work on surge, air, or electric-over-hydraulic brakes.
If that sounds like I know what I'm talking about, don't be fooled. I asked this question here in a panic shortly before picking up my trailer!
Old 05-16-2013, 06:29 PM   #8
F450Harley's Avatar
2006 30' Classic
Yonkers , New York
Images: 44
Duramax Factory IBC No..No on electric-over-hydraulic "DISC" brakes
Attachment 185884
Congratulations on your new purchase!!
My 2012 Denali Duramax HD integrated did not work on electric-over-hydraulic "DISC" brakes. I had to go with Maxbrake controller so check to see if the PO upgraded to disc brakes before you head out.
F450Harley is offline   Reply With Quote
