05-17-2017, 09:56 AM
Princeton
, New Jersey
Factory brake controller HELP
Is anyone using a Chevy factory brake controller. If so does it work or are you considering an after market controller.
I am working with a 2012 Chevy that has a factory controller.
2004 Excursion 4x4
05-17-2017, 10:54 AM
2006 19' Safari
East Greenbush
, New York
My 2008 came with one. Works very well.
Matt
2006 Safari Bambi 19'
2017 Silverado LT Z71 Double Cab 1500
05-17-2017, 11:11 AM
2017 25' Flying Cloud
Florence
, Alabama
I have a 2015 gmc with one, maybe same. It has worked well. Why are you considering after market?
The Colonel and Southern Belle
05-17-2017, 11:38 AM
Princeton
, New Jersey
My daughter had traded her truck for a 2012 and I had removed the Prodigy from the old truck.
We had no idea the 12 had a controller built in so I just did the installation and then found the conflict. Once both were installed the question can up. If there were bad reactions to the factory unit I would have to cut it out in order to get the Prodigy to work so I asked first.
2004 Excursion 4x4
05-17-2017, 12:46 PM
2006 19' Safari
East Greenbush
, New York
I like the factory controller better than any 3rd party one. It just feels more responsive. Yes, it's subjective. But, if I hated it, I would have wired in my old prodigy, even though it's a pain.
The only downside to a factory brake controller is that some don't work well with some hydraulic disc brake actuators. In that case, there might be an adapter available; or I've heard of wiring in a pair of magnets in parallel with the actuator to fake out the factory controller.
If I ever need a new truck, factory towing mirrors and factory brake controller are mandatory.
Matt
05-17-2017, 01:09 PM
2000 30' Excella
Toledo
, Ohio
2015 and newer Gm controllers work with disc brakes .I'm happy with mine in my 09 except for the no disc brake issue .
05-17-2017, 01:15 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We had to clip the blue wire to remove data awareness to the factory brake controller on our 2012 Ram 2500 HD Cummins as it was not compatible with the disk brake conversion on our Classic. No error codes were thrown after the wire was cut.
05-17-2017, 01:23 PM
2015 19' Flying Cloud
Ashland
, Kentucky
GMC Integrated Brake Controller
I used to have the Prodigy on my Mercedes and it worked very well and included it when I traded up to a 2016 GMC Yukon with Max Towing Package with the integrated brake controller.
I must admit that I was a little skeptical at first, but the hook-up was seamless and the controller actually works better on hills working with the vehicles stability system.
As others have stated, I would try it first, I think you'll be pleasantly surprised - I was.
One Long Shot
Beastie - 19'FC
The Big Beast - GMC Yukon w/Max Tow Package
Held together with the Husky Centerline Hitch
05-18-2017, 12:42 PM
2013 31' Classic
billings
, Montana
The factor controller on. My 2017 ram 2500 works fine ,so far no problem
