Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 11-06-2009, 03:09 PM   #1
Profile:  2005 19' Safari
Phoenix , Arizona
Since they are both made by Tekonsha, they may use the same harness. However, I'd verify that before you try to use it, even if they look the same (the wiring might be different).
A Ford harness for the Prodigy is only around $10, and the bracket mentioned by "crispyboy" makes it really easy to move the Prodigy between vehicles.
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 11:46 PM
How to install a Prodigy brake controller Airstream 65 Brakes & Brake Controllers 1 04-07-2007 03:58 PM
Prodigy brake controller issue crispyboy Brakes & Brake Controllers 2 09-25-2006 02:27 PM
Is Prodigy the best brake controller? silverback 2003 International CCD 13 07-28-2003 06:03 AM
Prodigy Brake Controller bdbluegrass Brakes & Brake Controllers 12 04-24-2003 11:14 PM
