Old 05-06-2014, 03:21 PM   #1
2008 31' Classic
Rochester , New York
Endeavor Brake Controller
We are headed back to Cincinnati to pick up our Airstream. On the last try the brake controller we had installed did not work. Having a new controller installed in Cincy so we can obtain local help if needed.
We are planning on buying a Hayes Endeavor controller and as I read the manual, the controller senses the deceleration of the TV and applies power to the brakes on the trailer. If at a standstill, we can check out the circuit by pushing the manual slide on the brake controller and we will hear the Airstream brakes activate.
If this is the case, then if we are stopped and push on the TV brake pedal, we should not hear the Airstream brake controller activate.
Do I have this correct?
Thanks in advance for the replies.
CharlieSK is offline   Reply With Quote
Old 05-06-2014, 06:31 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The manual lever will apply brakes in proportion to how far you move the lever whether you are rolling or stopped.
While moving the controller will only apply the trailer brakes proportional to the force applied to the TV brakes. You should see an amperage reading displayed on the controller showing the amount of current going to the trailer brakes.
2004 Excursion 4x4
What Brake Controller Are You Using On Hydraulic Brake Classics? KJRitchie 2006 - 2010 Classic (all lengths) 30 09-25-2014 12:03 PM
Brake lights, brake controller not functioning adwriter73 Brakes & Brake Controllers 17 01-16-2014 09:37 AM
E53 w/ Tekonsha brake controller lights 3rd brake light when manual lever applied warmrain Brakes & Brake Controllers 10 11-14-2013 09:35 AM
Brake controller or trailer brake problem? (newbie alert) jornvango Brakes & Brake Controllers 2 11-01-2012 02:17 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
