Old 07-02-2012, 11:25 AM   #1
Emergency breakaway cable
Found one of two wires of the wires severed. Does this disable the trailer brakes? Does it cause a problem when traveling? How would I go about repairing this? Should I just buy a new one?
murphy is offline   Reply With Quote
Old 07-02-2012, 12:35 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
One wire (usually with a loop, aka breakaway cable) connects somewhere to the tow vehicle. If that is the one broken, you will have no emergency activation if your trailer somehow loses it's connection with the hitch. If it is the power side of the switch, power will not be applied to the brakes of the breakaway switch is activated.
I have damaged the break away cable before. You can take that cable along with the connecting pin to a RV supplier or store and get a match. Note that if you pull the breakaway cable with it's connector out of the switch, please be sure to pull a battery cable off otherwise your trailer brakes will be locked on. Leaving that pin out will drain your battery or could overheat the brake magnets dependent on the charge of the battery and how long the pin is left out.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-02-2012, 12:55 PM   #3
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
Depends how much wire is left to join together. If you've got enough, you can strip each end and use a butt-splice for the repair. Use a heat-shrink one so you can seal it after without using a bunch of tape.
If not, they are cheap, but then you are making two joints to wire the new one in...
Friday is offline   Reply With Quote
Old 07-02-2012, 01:22 PM   #4
warbler5's Avatar
2004 30' Classic
Roseville , California
Send a message via AIM to warbler5
My advice: replace it, and keep the damaged one as a spare.
2004 30' Airstream Classic
2011 GMC 3500HD Duramax
Hensley Arrow hitch
Jackson Rancheria, 10-12 Oct 2014
Pinnacles Nat'l Park, 20-22 Feb 2015
Casini Ranch, 10-12 Apr 2015
AIR #6287
TAC #CA-26
WBCCI #3933/4CU
warbler5 is offline   Reply With Quote
Old 07-02-2012, 03:31 PM   #5
Emergency break away cable
Thanks for your responses. Just one more thing, does this disable the electrical
brakes on the trailer or have any effect on them?
Old 07-02-2012, 05:11 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Assuming you are talking about the electric wire not the cable pull a break will not disable the brakes but will disable the break away switch.
Old 07-02-2012, 06:28 PM   #7
2007 27' Classic FB
Ridgefield , Washington
I just went down to Home Depot and bought some supplies to make a new one. Thinking about getting one of those accordion type of lines.
John & Lisa
Woosch is offline   Reply With Quote
