Old 01-25-2009, 09:15 PM   #1
msieber109's Avatar
1966 24' Tradewind
1975 29' Ambassador
Greenfield , Massachusetts
Electrical Dilemma - brake controller wiring at disconnect
My connector on the vehicle side shorted out. I realized this because My trailer brake controller was acting as if my trailer was connected and it wasn't. I disconnected the connector at the rear bumper completely and that problem went away. Found the short. Replaced the connector and the brake controller seems to be acting like normal.. unfortunately I am unable to get to my Airstream, because of the snow, just to plug it in and see if it works.
Now my question is the lead coming from the brake controller... is it supposed to have 12 volts or 0 volts all the time? Mine is reading 0.
Also I think I have another problem, my 12 volt lead is only reading 3.9 volts with the vehicle on or off. I checked every fuse I could find and all are good.
It is an 06 GMC 1500 CC and I am using the factory wiring harness.
Any thoughts.
Thank you
msieber109 is offline   Reply With Quote
Old 01-25-2009, 09:21 PM   #2
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Hi,
The terminal coming from the brake controller to the rear receptacle socket on the truck should have 0 volts at it when brakes or lever is not applied. Depending on the set up of your trucks electrical system the 12volt power lead at this same receptacle could have either battery voltage or chargine system voltage depending on if the truck is running or not. It may have a way via relay to shut off the voltage when the truck is shut off. dont know. But i do know you shouldnt have 3.9 volts at the charge wire.. thats beginning to sound more like the brake controller when activated slightly.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 01-26-2009, 11:49 AM   #3
msieber109's Avatar
1966 24' Tradewind
1975 29' Ambassador
Thanks Vinnie
I am going to disconnect my brake controller and recheck. Just to make sure it isn't that.
Does anybody know of a hidden fuse or a relay in the 12 volt lead? because if it is my brake contorller going bad, then I still don't have 12 volts to the trailer.
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
wiring impulse brake controller remcolent Brakes & Brake Controllers 2 08-06-2007 08:48 AM
brake controller wiring? Chuck Brakes & Brake Controllers 1 09-30-2004 07:10 PM
New Brake controller Tin Hut Brakes & Brake Controllers 4 08-23-2004 09:07 AM
Ok, I need a brake controller Chuck Brakes & Brake Controllers 6 06-07-2002 12:43 PM
