Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 08-31-2006, 07:51 PM   #1
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Electric wire splice on magnets
I'm getting ready to bring home my new '77 and refurbed and checked all 4 brake systems, except for one broken spring they were great.
Then I checked the two wires going to the magnet from behind the wheel.
The 2 wires were twisted with wire nuts and taped
So i cut the wire nut out to replace it with a nice butt end connector,
that isn't going to happen one wire is a 14ga and the other 18ga.
How are these connections or splices supposed to be done?
I want to redo all 4 wheels and not worry about these splices
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 08-31-2006, 08:04 PM   #2
Jim Clark
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
I soldered mine and put shrink wrap over them.
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim,
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 08-31-2006, 08:06 PM   #3
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Lipets,
I'm with ya' on the but connectors. Just one more thing..............they should be sealed with heat-shrink tubing to keep them from corroding. That would make them the perfect connection. I use this method in just about all of my exposed electrical work.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 08-31-2006, 08:33 PM   #4
LI Pets
Silver Mist
LI Pets's Avatar
Sounds like a plan any suggestions on what to use to heat shrink them?
WBCCI
Old 08-31-2006, 08:36 PM   #5
scottanlily
Profile:  1960 24' Tradewind
santa barbara , California
Hello lipets,
the 14 and 18 gauge wire can be spliced with the blue butt connectors,
both will fit ,the red connectors allow 18 but too small for 14 . Seal them with liquid electrical tape ,that have it at OSH .Soldering is better ,the crimp way
is fine ,just seal the ends up ,shrink tubing as lewster says works great .
you do not want corrosion starting on the connections ,and it will if not
prevented from doing so .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 08-31-2006, 08:47 PM   #6
LI Pets
Silver Mist
LI Pets's Avatar
The blues ones were to loose on the small wire, I think I can solder them in the same time as screwing around with the connectors.
WBCCI
Old 09-01-2006, 12:01 AM   #7
lewster
Commercial Vendor
lewster's Avatar
Tech secret
Bob,
I'll give you a little secret that I use to join dissimilar wire sizes (but let's keep this between you and me! ) Use the smallest butt connector that will fit the largest wire. Then cut the smaller wire so you strip twice the normal amount of insulation from the end. Then fold the end on itself in half. This will give you a larger amount of strands to clamp into the butt connector, and both wires will be tight.
BTW, I use a heat gun from Harbor Freight (about $10 IIRC) for heat sealing. I also made a little curved attachment that fits over the end that directs the hot air flow all around the heat shrink tubing so you can effectively shrink it in one pass from any direction.
AIR # 10325
Old 09-01-2006, 01:26 AM   #8
scottanlily
Agree ,I use that special secret way almost everyday on electrical work.
Scott
Old 09-01-2006, 06:27 AM   #9
Beginner
Profile:  1984 31' Excella
Norfolk , Virginia
Images: 11
Splicing
One more thing that you can do is to put a tie wrap (the smallest one that you can buy) over the end of the tape wrap then coat with the liquid electrical tape. This makes an excellent environmental splice.
Beginner
Beginner is offline   Reply With Quote
Old 09-01-2006, 09:53 AM   #10
Jim Clark
Jim Clark's Avatar
Radio Shack has a small packet of assorted shrink wrap tubing. I also remember I coated the connection with bulb grease before I shrunk the tubing. Be sure to slide the tubing on the wire before you solder the connection.
Thanks Jim,
Old 09-01-2006, 12:04 PM   #11
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
That is how they were sent from the factory, and as far as I know, how Airstream attaches them to this day.
Old 09-01-2006, 12:31 PM   #12
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
To chime in with O63, how you found them is the supposed to way. All the other ways listed above are better than what you found and are slower at replacement when it comes time to replace the magnets. And you will replace the magnets. Not really right or wrong. Just different and more secure.
>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 09-01-2006, 12:49 PM   #13
Tom Nugler
Tom Nugler's Avatar
Profile:  1967 20' Globetrotter
McHenry County , Illinois
Originally Posted by scottanlily
Hello lipets,
Make life easy on yourself and head to the "good" auto parts store in your area. The better stocked stores have butt connectors that have a sealer coating the inside of the plastic shell.
The plastic is heat shrink material and when heated, the sealer melts, the shell shrinks and waterproofs the connection.
We've been using these at the shop for over 10 years now and I have never seen a failure of a properly spliced wire.
Tom.
Airstream Forums Member # 2806
WBCCI # 6411
Not All Who Wander Are Lost.
Tom Nugler is offline   Reply With Quote
Old 09-01-2006, 01:11 PM   #14
Jim Clark
Jim Clark's Avatar
Tom.
Marine supply stores also have this type of connector.
Thanks Jim,
voltage for electric jack maznblu Towing, Tow Vehicles & Hitches 3 04-16-2004 09:32 PM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 07:51 PM
Extra wire susan martin Batteries, Univolts, Converters & Inverters 3 09-21-2002 08:52 AM
Figuring out what is going on with my trailers electric setup... Andy R Electrical - Systems, Generators, Batteries & Solar 1 03-30-2002 11:59 PM
Electric Brake Wiring JW84345 Brakes & Brake Controllers 3 03-26-2002 10:40 PM
