Old 05-14-2005, 06:28 PM   #1
Electric trailer brakes
Hello,
We have a 72 - 27 ft Overlander travel trailer. On the way home from taking our trailer out of storage, the right rear brake locked up. When I removed the drum, the adjusting screw assembly and spring fell on the ground and they were heavily scored. The drum pads also had some damage at the lower edges. What I need is information for replacement of the drum pads and brake parts to get us under way for the summer season.
Thank you in advance for any infonmation you can provide.
Kurt & Eve
Kurt & Eve is offline   Reply With Quote
Old 05-14-2005, 06:51 PM   #2
Images: 14
trailer brakes
You can probably buy a new Dexter backing plate with all the brake hardware already mounted at your local NAPA auto parts dealer. Unbolt yout old backing plate and take it to the store. My NAPA guys were able to figure out the dexter replacement parts. The last ones I bought were ~$55 per wheel. Dexter also has a on-line ordering service if you can figure out which parts you need.
I think Kelsey-Hayes brakes were on older Airstreams but they were bought out or or out of business now.
http://www.dexteraxle.com/products___literature
http://i.b5z.net/i/u/1080235/f/Brake...in._Brakes.pdf
NOTE: Don't just fix one wheel, you are supposed to replace the brakes on each side of the axle to ensure good braking action.
bjond is offline   Reply With Quote
Old 05-14-2005, 08:05 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Kurt & Eve!
I agree with Herb Spies, the fully loaded backing plates are the way to go. When my Overlander experienced a similar problem just as I returned home from the 1999 WBCCI International Rally in Dayton, I had a set of four of the fully loaded backing plates installed on my coach. The Brand X dealer who handled the install (I was more than 600 miles from Ace Fogdall RV who does all of my routinely scheduled repair work) also suggested that the drums be trued and the bake shoes matched to the drums -- these machine shop procedures resulted in the smoothest acting electric drum-type trailer brakes I have ever experienced.
If Airstream was still using the 3,000 pound aggressive trailer brakes when your Overlander was built, you will definitely want to perform the same repair at both ends of the axle -- in fact, you may find that it is necessary to service all four wheels. Unless things have changed since 1999, 6,000 pound aggressive was the only rating available in the fully loaded backing plates -- I suspect that mixing 3,000 pound aggressive rated brake sets with 6,000 pound aggressive rated brake sets on the same coach could prove problematic.
Good luck with your repairs!
Kevin
Kevin D. Allen
AIR #827
Old 05-14-2005, 08:37 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
pioneer
kurt and eve
here is a midwest supplier of backing plates etc.
they have reasonable prices!
http://www.pioneerwheel.com/
john
you call them ferrets, i call them weasels.
Old 05-14-2005, 08:53 PM   #5
Somewhere , Indiana
Originally Posted by Kurt & Eve
Hello,
Kurt & Eve
Kurt & Eve,
You should definitely replace the pair, not just the bad brake. In today’s throw away society, you will likely spend more trying to replace parts then purchasing new loaded backing plates (not to mention the piece of mind factor). If you need drums turned, be sure to check the manufacturers maximum re-bore dimensions. Turning too much off of a drum can be dangerous also.
I hope this helps ,
Henry
axleman is offline   Reply With Quote
Old 05-15-2005, 08:18 AM   #6
Thanks Henry
Old 05-15-2005, 08:21 AM   #7
Thanks Kevin
Old 05-15-2005, 08:23 AM   #8
Thanks Herb
Old 05-15-2005, 09:36 AM   #9
Kelsey-Hayes was bought by a German interest.
The new company's name is Hayes Lemmerz. I know they still make brake controllers under the Hayes Lemmerz name. They also make brakes and drums for commercial applications.
http://aftermarket.hayes-lemmerz.com/
Anon is offline   Reply With Quote
Old 05-22-2005, 04:25 PM   #10
Loren's Avatar
Kurt & Eve,
I had a brake disintegrate on a trailer we owned some years ago. We fixed the brake but re-used the drum. This was a HUGE mistake.
In our case, the drum had gotten hot, and apparently had weakened. A couple of years after the brake re-build, that wheel came off the trailer at about 50 mph in traffic. By some miracle, no one was hurt and nothing was damaged. All of the eight lug studs were sheared off.
I would strongly recommend replacing the drum on the side that had the problem. The peace of mind is worth it to me.
Loren
2012 New Horizons Travel Trailer (formerly an Airstream owner)
2008 Dodge 2500 diesel with Equal-i-zer hitch.
Loren is offline   Reply With Quote
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
need advice re. 1969 tires, brakes, etc. Dave Cole Tires 6 01-29-2007 06:04 AM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Trailer Friendly Camping California bkpine Our Community 31 08-19-2002 01:26 PM
New years added to Trailer Forum 83Excella Our Community 3 07-08-2002 06:24 AM
