Old 09-19-2016, 09:24 PM   #1
wtjaynes's Avatar
1974 27' Overlander
Flirence , Alabama
Electric drum brakes
I have a 1974 Overlander. Today I started replacing my bearings and decided that my brake shoes need to be replaced. I have a few questions.
Using the part number in the manual the local parts store couldn't find a match for the shoes. So does anyone have a part number or source for the brake shoes.
The electric brakes are working as far as I know but should I go ahead and replace the magnet unit too?
Would I be better off in the long run to just buy the whole unit?
I'm also looking for a good retail source for all of this.
Wes
wtjaynes is offline   Reply With Quote
Old 09-19-2016, 09:49 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Loaded backing plates, shoes, magnets and springs, are available at RV supply stores and online, such as etrailer. Much cheaper than replacing individual parts.
Bill
Wes
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 09-20-2016, 03:52 PM   #3
wtjaynes's Avatar
1974 27' Overlander
Flirence , Alabama
Thanks for the info. I found the backplate unit for less than $50 at a local trailer supply store.
Old 09-20-2016, 04:52 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
That is a great find and local as well.
>>>>>>>>Action
Old 09-20-2016, 04:57 PM   #5
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario
Send a message via AIM to TRIPPPIN Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
Are the "loaded units" all good quality or is there any superior complete packages?
TRIPPPIN is offline   Reply With Quote
Old 09-20-2016, 05:10 PM   #6
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
No question - better to replace the entire unit, less expensive, easier, and a better job!
What's not to like!
I did that while camping in Florida last winter - took me maybe an hour per wheel. I did take an electric impact wrench along and glad I did as the bolts (5 I think in my case) were somewhat rusted - they all came apart in the end without breaking any breaking though.
I soldered the wires to the new magnets but had to clean corrosion from the wires on the trailer to do a decent job.
The brake assemblies seem to be pretty standard - I bought mine from a local place that builds utility trailers, horse trailers etc., for less than $50 each for 12" assemblies - just need to ensure that the mounting bolt pattern matches yours as I think there may be 4 bolt and 5 bolt assemblies. They also had inexpensive drums but mine seemed ok for now.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 09-21-2016, 05:23 AM   #7
wtjaynes's Avatar
1974 27' Overlander
Flirence , Alabama
Brian, mine were previously connected with wire nuts. Also now my wires are a little short. I'll have to add a short splice. Can I use butt connectors or does it need to be soldered?
Wes
Old 09-21-2016, 06:23 AM   #8
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
If you don't mind me chiming in..... I have heard differing stories about soldering, butt splices, and wire nuts. I think any of those methods would be fine as long as you start with clean connections, join them with any of those methods, spray them with an anti-corrosive , and cover the connection with heat shrink tubing.
Make sure that you have enough wire at each connection to account for full travel of the suspension without putting stress/binds on the wires.
PaulnGina is offline   Reply With Quote
Disk/ drum brakes? 68Streamline Jacks, Stabilizers, Lifting and Leveling 10 02-20-2014 09:29 PM
Help!!! finding spring for drum brakes bmklawt Brakes & Brake Controllers 13 04-22-2010 07:24 AM
disc vs drum brakes Brad Hunt Brakes & Brake Controllers 71 07-23-2008 03:23 PM
Disc vs Drum Brakes? Thrift Brakes & Brake Controllers 39 08-11-2007 01:19 PM
Trailer Brakes - Drum to disk upgrade safarinight Brakes & Brake Controllers 26 07-17-2007 06:32 PM
