Old 05-20-2010, 05:03 PM   #1
shiny1973's Avatar
1973 25' Tradewind
North Fort Myers , Florida
electric brakes
Hello one and all!
I need to put on electric brakes on my 1973 25 airstream. I dont know if I should take it to a dealer and have them do it, or if I can do it myself. I dont even know where I would begin to look for the parts. Any advise would be greatly appreciated. Dave
shiny1973 is offline   Reply With Quote
Old 05-20-2010, 05:12 PM   #2
Originally Posted by shiny1973 View Post
Hello one and all!
Replacing the brakes is easy as pie.
You don't even need a jack.
A couple of 2 x 6's will let you lift the trailer high enough, on one tire, and suspend the other.
You can then remove that tire and wheel, and then replace the brake backing plate.
Do that 4 times and your done.
Old 05-20-2010, 05:17 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are comfortable with nuts and bolts mechanical work there is no reason not to do it yourself. The backer plates simple bolt into place and the electrical connection is just connecting 2 wires at each brake. No polarity to the wires. Adjusting the brakes is standard, tighten the star adjuster till the wheel will not turn and then back off 4 clicks on the star adjuster.
The more important task will be setting and adjusting the wheel bearings as you put the drums back on. Use a pair of channel pliers to tighten down the wheel nut, while turning the drum, till it is snug. Now back off on the nut about 1/8 of a turn or until you can insert the cotter key. The important thing the drum wants to have some in and out play when you are done. TOO TIGHT is wrong.
2004 Excursion 4x4
Old 05-20-2010, 06:50 PM   #4
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
You can get the backing plates at Northern Tool,you might as well get a bearing packer,and some high grade wheel bearing grease,there is one in N.Ft. Myers,now the wheel seals are a different matter,take an old one to NAPA and see if they have a double lip seal,you will want to check your
brake drums when you pull them,if they are smooth,scuff them up with some 80 dry sand paper,if they are grooved you need to get them turned or back to N.T.to get new drums.
Install backing plates,connect electric,pack wheel bearings,install seals ,replace drum.adjust brakes,install wheel and torque nuts,drive off ramp,you have 1 wheel done,only 3 more to do .
They will be easier,first 1 is the hardest.Dave
easyride is offline   Reply With Quote
Old 05-21-2010, 06:12 AM   #5
shiny1973's Avatar
1973 25' Tradewind
Thank you all so much. I will keep you posted when I get them done. It sounds pretty easy now with all the direction! Thanks again!
Old 11-06-2010, 07:16 PM   #6
1977 27' Overlander
Blue Ball , Pennsylvania
Is this for replacing old electric brakes with new? I've got a 1975 with non-working vacuum brakes, I need to upgrade to something, something that works anyway!
hoppingviola is offline   Reply With Quote
Old 11-06-2010, 09:56 PM   #7
Some parts are still available for the original vacuum operated disc brakes.
Also the syncronizing valve can be rebuilt, which is the usual cause of those brakes not working.
Old 11-07-2010, 07:09 AM   #8
1977 27' Overlander
Carrollton , Texas
Had totally new brakes system done by A/S repair shop here and new shocks installed . Replaced the Vac system on the 77. Cost about $1600 total.
KL's 77 is offline   Reply With Quote
Old 11-07-2010, 01:32 PM   #9
1977 27' Overlander
Wow, $1600 is a lot - is that something that a handy kind of person could do? I'm fine keeping the disc brakes if I can switch away from the vacuum system. Oy! I'm reading the archives as fast as I can, so I can understand what questions to ask... Good thing I've got some months before she needs to get on the road.
Old 11-07-2010, 02:55 PM   #10
There are new style actuators available that you can add to your system, which does away with the need for any vacuum.
Old 11-07-2010, 03:46 PM   #11
1986 31' Sovereign
Miami , Florida
You might want to call Andy at Inland and ask him about the self-adjusting brakes. One less chore to do...
mike
New electric brakes don't Lumatic Brakes & Brake Controllers 25 06-01-2008 08:21 AM
Electric Brakes 61 Bambi Brakes & Brake Controllers 5 05-17-2007 06:13 AM
electric brakes Al1 Brakes & Brake Controllers 16 02-08-2005 07:59 PM
more about electric brakes openroad Brakes & Brake Controllers 14 01-03-2005 07:51 PM
Electric Brakes dbaverb Brakes & Brake Controllers 7 09-12-2004 08:27 PM
