Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 02-09-2007, 09:51 AM   #1
61 Bambi
Profile:  1961 16' Bambi
Buckeye , Arizona
Electric Brakes
Do I need to hook up electric brakes to my 16' Bambi? If so any suggestions where to have that done in Arizona? What about sway bars and lifters?
61 Bambi is offline   Reply With Quote
Old 02-09-2007, 11:00 AM   #2
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
Brakes are a good thing. They may not be immediately necesary if your tow vehicle is big enough. Take it to the Airstream dealer in Tucson Oasis if they are nearby. Otherwise any trailer place can hook you up and sell you a controller. Same thing with weight distribution. If you have a truck they may not be necessary, but if you are towing with a small SUV or car they would be recommended.
Old 02-09-2007, 11:15 AM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
By law you would not be required to. Your Bambi is under the 3000 lb limit most states (Arizona included) have set. But why not? If all you need to do is add a brake controller to your Yukon, I would do it. You could get a controller like the Prodigy with the proper cable and just mount it and plug it in. If you do it yourself the cost would be around $150.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 02-10-2007, 10:03 AM   #4
61 Bambi
Buckeye , Arizona
Thanks for the advice. You are so right. Why not be safe.
Old 05-16-2007, 10:46 PM   #5
rbrown
rbrown's Avatar
Waterloo , South Carolina
Post Brakes or not
I disconnect the brakes on my 1961 Bambi when I tow with my SUV Merecedes and then I commect my brakes when I tow with my 1965 Mustang. Nothing but the ball hitch.
Thousand of miles.
Richard
rbrown is offline   Reply With Quote
Old 05-17-2007, 07:13 AM   #6
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Thousand of miles.
Richard
Your MB has more mass than the Mustang, so it would have an easier time stopping the little trailer than would your pony car.
Even though you didn't ask, a friction-type sway control bar is much less than $100, and would help keep things straight while towing.
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 06:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 08:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 08:56 PM
Heeeelp! My brakes have failed...any one had a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 04:04 PM
conversion from vacuum/disk to electric brakes excelladep Brakes & Brake Controllers 2 05-30-2002 12:54 PM
