Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 03-25-2002, 10:19 PM   #1
JW84345
JW84345's Avatar
Profile:  1969 27' Overlander
, Michigan
Electric Brake Wiring
Getting ready to depart for a trip to Florida with our 69 Airstream Overlander. Brakes are only working on one side. Problem is that the wiring on the curb side is disconnected. Easy enough to fix except it is not obvious how to wire them back. The wired side provides no clues. I hope one of you can help.
1. Two white wires lead to the brake magnet.
2. A white and a black wire supply power from the trailer.
I am guessing that polarity is not an issue for proper functioning of the brakes. Only current is required. Is that correct? If not, how does one determine how to hook up + and - ?
I only spent a few minutes under the coach with a flash light, maybe I'm missing something.
Any help from past experience is appreciated.
JW84345 is offline   Reply With Quote
Old 03-26-2002, 07:50 AM   #2
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
Jim,
I remember Andy from Inland posting that polarity is not an issue.
But do not take my word for it. I am sure Andy will confirm this.
Do your travel plans still allow for a Mystic Springs stop-over?
PeterH-79MH is offline   Reply With Quote
Old 03-26-2002, 10:07 AM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Trailer electric brake magnets are not "polarity" sensitive. However, it is very important that they be wired in parallel, and one side grounded to the trailer frame, as Airstream wires them. Andy
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 03-26-2002, 10:40 PM   #4
JW84345
JW84345's Avatar
, Michigan
Peter, Andy,
Thanks for confirming the polarity issue on the brakes. Now I only hope the temperature breaks the freezing point tomorrow so I can work out there without going numb!
Peter,
With 22 - 24 hours drive time each way we are on a tight schedule. Unfortunately, Mystic Springs is a bit too far west for a convenient stop over on the way back.
I am looking forward to some nice pictures from the rally on this site!
Brake Wiring Myrjer Brakes & Brake Controllers 8 04-26-2004 04:55 PM
trailer side brake wiring diagram? munimula Brakes & Brake Controllers 5 10-27-2003 11:38 AM
Electric Brake Question 68 Suburban Brakes & Brake Controllers 6 03-04-2003 09:09 PM
Electric Brake Question. 68 Suburban Brakes & Brake Controllers 7 10-11-2002 10:14 AM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 02:05 PM
