Old 11-28-2014, 11:07 AM   #1
JRF0st3r's Avatar
1967 22' Safari
West Fork , Arkansas
electric brake wiring?
For our 1967 Safari I am replacing TV to trailer wiring as well as brakes & axle, among other items. The new brake wire has been routed to the brakes but then I found a second wire to each brake, assume a common ground. I've anchored the common ground wire to the frame but is it necessary to also have a direct ground wire connection to each brake?
Advice would be appreciated!
JRF0st3r is offline   Reply With Quote
Old 11-28-2014, 11:11 AM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Each magnet will need a hot wire and a ground.
I would probably wire each magnet ground to the same eyelet you connected to the frame to assure an excellent ground.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Electric brake wiring suggestions? cuyeda Brakes & Brake Controllers 0 10-19-2012 06:49 PM
Need help with electric brake wiring... Mr. D Mechanics Corner - Engines, Transmission & More... 2 05-03-2012 06:14 PM
1967 electric brake wiring phoney Brakes & Brake Controllers 8 07-28-2009 11:41 AM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
Electric Brake Wiring JW84345 Brakes & Brake Controllers 3 03-26-2002 09:40 PM
