Old 06-05-2012, 03:53 PM   #1
1987 32' Excella
Hudson , Florida
Electric Brake Question
Do I have to unplug my electric brakes when backing up. I have an '87 Excella. Don't know if not unplugging my brakes is causeing a problem (noise on backing up) or something else. Have had to replace magnet, and brake shoes on one brake because a spring broke. was this caused by backing up with the brakes plugged in? The owners manual doesn't address this.
kerrie is offline   Reply With Quote
Old 06-05-2012, 03:55 PM   #2
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
You don't need to unplug your brakes to back up.
Diesel1 is offline   Reply With Quote
Old 06-05-2012, 03:56 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Electric brakes work in both direction so do not disconnect them. The stopping power is not as great because of the nature of the leading and trailing shoes when used in reverse but then again you are not backing up as fast as going forward.
As for the repair buy a complete backer plate assembly because it i cheaper than rebuilding your current one.
2004 Excursion 4x4
Old 06-06-2012, 05:45 AM   #4
1987 32' Excella
Hudson , Florida
Smile
Thanks for the info!
