Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 03-04-2003, 04:15 PM   #1
68 Suburban's Avatar
Profile:
Electric Brake Question
Where do the electric trailer brakes gound? The power comes through the trailer plug to the trailer, but how are the electric brakes grounded? Does the trailers batteries need to be hooked up to get proper operation of the electric brakes? I know the battery has to be hooked up for the break away switch, but how about normal operation of the electric trailer brakes? Thanks
Here is the link to Dingo's trailer:
1968 Avion T-22
68 Suburban is offline   Reply With Quote
Old 03-04-2003, 05:21 PM   #2
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Brake wiring
There should be a white wire (ground) and a blue wire (voltage) going to your brakes. The white wire hooks to a ground bus in the trailer that is connected to the ground wire in the truck connector.
No, you do not need a trailer battery for the brakes to operate with the exception of the breakaway switch.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 03-04-2003, 05:27 PM   #3
Profile:
According to my manual 1994-1995 the ground from the 7 way plug goes to my fuse distribution panel. Then this is grounded to the chassis of the trailer.
John is offline   Reply With Quote
Old 03-04-2003, 06:20 PM   #4
Profile:
Ok thanks. Now if I have all my trailer light working, I have a good ground for the tow vehicle and the trailer, but the ground from the brakes could still possibly be faulty? Am I understanding this right? Thanks
1968 Avion T-22
Old 03-04-2003, 06:39 PM   #5
Profile:
You're correct in your thinking. You could have a break at the brake assemblies themselves.
The ground from the trailer brake assemblies routes back to the same point at the fuse distribution panel.
Are your brakes not working?
John
Old 03-04-2003, 06:56 PM   #6
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
I think there are a couple of similar threads running. 68 Suburban (I didn't catch your name, sorry), are you talking about an Airstream or the Avion in your signature. I haven't been deep into an Avion but basic wiring should be the same. If there were to be something out of the ordinary, it would probably be the Airstream and not your Avion. Airstream has a way of doing things unique, for the sake of uniqueness sometimes. Just wanted to make sure your comparing oranges to oranges.
Randy
Old 03-04-2003, 08:09 PM   #7
Profile:
it is on my Avion. I have not checked everything yet, but I am not getting the green light on brake controler like I am suppose to . Im sure it is something minor, but I wanted to ask questions before I look at it. Thanks guys
1968 Avion T-22
Pingbacks are On
Brake System Question joshua32064 Brakes & Brake Controllers 8 09-24-2003 09:37 AM
Brake Controller Question Rickk48 Brakes & Brake Controllers 3 03-17-2003 03:30 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
Electric Brake Question. 68 Suburban Brakes & Brake Controllers 7 10-11-2002 09:14 AM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
SEO by vBSEO 3.1.0
