Old 06-08-2010, 09:02 PM   #15
1986 25' Sovereign
Plant City , Florida
Question
Originally Posted by HowieE View Post
I am not sure why you are not willing to adjust the controller as per instruction.
The controller will vary the voltage and current so just measuring voltage doesn't tell you anything.
If I recall you said you had 7.8 volts at the controller and at the brakes. This indicates the wiring is good.
i can adjust the controller however I thought i knew how. I have adjusted the gain and sync to max. Are there typically any other controls for a reese brake controller?
Thanks again for your help and input on this as my head is hitting the wall again and again.
these are the instructions i followed.
http://www.bradstrailer.com/reesetrouble.htm
ck21084 is offline   Reply With Quote
Old 06-08-2010, 09:09 PM   #16
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have both set at MAX and still have poor braking you have a problem somewhere.
Jack up one side of the trailer and while spinning a wheel have someone hit the manual control. That should SLAM the wheel to a stop. If you do not get this reaction from each wheel its time to start some deeper investigation.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 06-08-2010, 09:31 PM   #17
Wise Elder
Jammer's Avatar
2010 30' Classic
Check and be sure that the controller is properly wired. The wire color codes can be confusing, and it is common to mix up +12, brake switch, and ground.
Check and be sure that the controller is properly grounded.
Check and be sure that the +12v connection to the controller is clean and tight. Check the voltage between the +12V and ground connections at the controller with brakes applied manually. If less than 11.5 volts, you have a problem in the power/ground wiring to the brake controller.
brake, not working, voltage
single wheel brake issue funkill Brakes & Brake Controllers 21 06-01-2010 01:43 PM
low voltage at Electric hot water heater jasper2222 Batteries, Univolts, Converters & Inverters 0 05-17-2010 05:44 PM
Voltage Issue Rayk Mechanics Corner - Engines, Transmission & More... 2 07-06-2004 10:38 AM
voltage for electric jack maznblu Jacks, Stabilizers, Lifting and Leveling 3 04-16-2004 08:32 PM
Tag Axel Brake Voltage / Amperage 87MH Mechanics Corner - Engines, Transmission & More... 1 11-11-2003 09:25 AM
