Old 06-09-2014, 09:40 PM   #1
donabston's Avatar
2012 25' FB International
Baton Rouge , Louisiana
Electric brake inspection/repair
I have a 2012 International 25' FB. In the very near future I will be replacing the full set of tires. I would like to have the brake pads/shoes inspected and replaced, if necessary.
Is there any special knowledge or skill necessary to work on the electric brakes?
Can a standard issue brake mechanic change out the parts, or do I have to go to a "trailer shop" to have the work done?
Thanks, Don
donabston is offline   Reply With Quote
Old 06-09-2014, 10:01 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Thanks, Don
Hi, my opinion; Anyone who can, and has correctly done, drum brakes on a car/truck should be able to do trailer brakes. Finding someone who can machine the drums for both the brake lining and the magnet surface will be the hard part. Unless you ride your brakes down every hill/mountain, a 2012 model shouldn't need new linings.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-10-2014, 12:46 PM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Thanks, Don
Depends on the shop. Depends on the mechanic. There have been reports of career mechanics lifting trailers in ways that have damaged them, so no job is idiot proof.
A trailer shop would be more likely to have the parts in stock and experience with electric brakes. They would be more likely to have a shop configuration conducive to working on trailers. And the mechanic would be sure to have worked on electric brakes before, probably sometime in the last week or so.
You choose
Old 06-10-2014, 03:00 PM   #4
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Electric brakes are almost idiot proof. They are about as simple as it gets. My scare would be how they jack up the A/S.
mhilley is offline   Reply With Quote
Old 06-10-2014, 11:22 PM   #5
donabston's Avatar
Thanks for the replies. I'm gonna read up on the jacking procedure.
Don
2010 28' FC Wheel & Brake Inspection Snaken49 2009-2015 Flying Cloud 0 09-23-2013 06:42 AM
Inspection and Repair Pilgrimsoul 1970-79 Tradewind 0 11-17-2011 12:58 PM
Questions about Jacking for inspection and repair badelson Jacks, Stabilizers, Lifting and Leveling 5 08-10-2007 12:38 PM
Dexter Brake Inspection Criteria Tarheel Brakes & Brake Controllers 14 04-11-2006 10:59 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
