Old 10-29-2011, 04:48 PM   #15
Mexray's Avatar
1978 28' Ambassador
Morada , California
I've gone to an 8-way cable - with 'twisty' wire ends...being color blind makes 'twisting' the proper wires a real challenge, however...
Name:	8 way cable.jpg
ID:	143956   Click image for larger version
Ray & Pat; Morada, CA
Old 10-29-2011, 06:52 PM   #16
Overland Adventurer
1998 19' Bambi
Denver , Colorado
Different is sometimes good
I agree, in regards to a slight theft deterrent, different is good.
In the event you need to be rescued/towed, odds are a tow truck will have temporary/magnetic lights that can be stuck to the bumper......
I guess it all comes down to overall functionality, quality, durability and cost...
I have used the Hella EXTENSIVELY...
never a problem. Your find liiks good too.
I would caution against the WD40... it is an oil, will ultimately harm plastics, and WILL attract dirt.
I think the name of the game is preventing the ingress of water and gook.
Some people think silicone grease prevents corrosion, it does, but it is also a dielectric, and will prevent the flow of electrons.
Maniscalco's is offline   Reply With Quote
Old 10-31-2011, 09:58 AM   #17
1969 27' Overlander
Albuquerque , New Mexico
True, WD-40 is oil based (no, it's no longer "fish oil"), and I couldn't imagine how the first person discovered it's good for "Ruemytism", but I've used it for many years for automotive use. It has never caused any problem with the plastic on the trailer plugs, and like you say, the best course is to keep the grime OUT of the connector. The WD-40 helps to repel the water from inside the contacts of the plug and creates a thin barrier, which prevents corrosion. I also spray it heavily into the plug assembly if it's accumulated dirt and grime. It flushes the gunk out.
Typically, the TV plug gets dirt and water into it, no matter what, since the cover isn't watertight. So you have to clean it out someway. Dirt is dirt. Doesn't matter how it gets there.
I've had great luck with WD-40.
Just my 2 cents.
edglenn is offline   Reply With Quote
Old 11-02-2011, 02:33 PM   #18
Vintage Kin
Fort Worth , Texas
Did more of a search for reviews last night. Not much yet, except with the horse trailer crowd.
Here's an install for a 5'er a couple of years ago:
Dunechasers
Toyhauler Magazine Review
brake, harness, 7 pin
