Old 01-11-2008, 09:43 PM   #1
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Dumped my Voyager ..... brake controller
Hi, when we bought our brand new Airstream Safari in September 2004 we got a free Tekonsha Voyager brake controller with it. And for over three years it has worked just fine, no complaints. On this forum I have read soooooo many good things about the Tekonsha Prodigy, so I bought a brand new Tekonsha P-3. I like the fact that I can set it up by numbers and can always set it where I like it instead of adjusting it by feel. And the adjustments can't be accidentally changed by someone turning the knobs, because it can't be changed unless the trailer is connected. Also it looks really good inside of my Lincoln. We will be takeing our trailer out in the first week of Febuary so I won't know how well it works until then.
Name:	PICT0663 (Large).JPG
ID:	52422   Click image for larger version
Name:	PICT0664 (Large).JPG
Name:	PICT0665 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 01-11-2008, 11:53 PM   #2
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Well, Bob, you can show it to me at Casini in April.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 01-12-2008, 08:00 AM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I am eyeballing that one myself. My old prodigy is reliable, and works ok, but it is inconsistant and requires adjustments often. My hopes are that the new P3 is better in that regard.
Can't wait for your first trip report.
Uwe
www.area63productions.com
Old 01-12-2008, 09:01 AM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I'm happy with my P3 also. I sometimes have to make adjustments after the trailer has been sitting for awhile but it so easy to do so. After using this controller for over 1,800 miles, I am sold on it's features.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-12-2008, 05:14 PM   #5
2008 31' Classic
Sweet Valley , Pennsylvania
I was just down to see my local RV guy who has been in the parts business for many years...real reliable sort. He told me he go a letter reguarding sending back P-3s if he had any on the shelf. He called it "a quiet recall" Any problem areas weren't explained to me and he told me he has sold quite a few with no problems reported. Its winter here I am in no hurry. He told me the new ones are on order and will be available in a few weeks. I don't think he was BSn me, since he knows I wasn't in a hurry and was going to buy from him anyway. Just thought I'd pass it on. I'm getting a P3 for my 2005 Silverado I just picked up to haul a 27 classic.
TROPHYJIM2 is offline   Reply With Quote
Old 02-07-2008, 11:47 PM   #6
Salem , Oregon
Images: 18
P-3 first test drive.
Hi, on our trip last week to San Clemente State Beach, I was able to set and test my new brake controller. The instructions said to set it to 6.0 and drive vehicle to 25mph. Then pull lever to the left and see if the brakes lock up. [Previously, my brakes would never lock up.] If the brakes lock up, then lower the voltage. If not, raise the voltage until if does lock up at 25mph. Mine locked up at 8.5 volts. Next step is to lower the voltage just enough to not allow the brakes to lock up. I set mine at 8.2 volts. Next step was to set the boost to match my tow vehicle to my trailer. I set it to boost #2. This was all done while driveing around my neighborhood before actually hitting the freeway. On this trip my Lincoln and Safari stopped smoothly and as one unit; No bucking, grabbing, or jerking. Driveing on the freeway, side streets, or parking lots [camp grounds] I never had to make any other adjustments. I'm glad I made the change.
Note: this controller can be set to work with drum or disk brakes so if for any reason I needed to help out someone by towing their trailer with disk brakes, I would be able to.
2005 Safari 25-B
Old 02-08-2008, 07:49 AM   #7
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
On this trip my Lincoln and Safari stopped smoothly and as one unit; No bucking, grabbing, or jerking. Driving on the freeway, side streets, or parking lots [camp grounds] I never had to make any other adjustments. I'm glad I made the change.
The bucking, grabbing etc. symptoms you describe sound exactly like what my beef is with the Prodigy.
Sounds like a P3 is on the horizon for me, too.
Does the Prodigy Harness plug into the P3?
On Edit - I just noticed that your previous brake controller was a Voyager, not a Prodigy. Oops.
Still, the Harness might be the same, can you tell?
Uwe
Old 02-08-2008, 07:52 AM   #8
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Ok, I will fax you my camping itinerary....lucky for you, most trips are close to home, so you won't have to tow my trailer so far. The next is San Clemente SB on the 29th. Spot 004. I'd like to arrive by 4:00PM for cocktails, please make sure the trailer is all set up, and the fridge is cold.
Uwe
Old 02-08-2008, 08:23 AM   #9
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Fwiw
I installed a P3 last fall when I got the new(er) truck. I have towed from south west Oklahoma to St Louis (part of the way in snow), then on to Nashville then to Padre Island and finally back to OK. I have been completely satisfied with the P3. I can't say how much better it is than the cheapy I was using, but I like to think it is better. I love the display and the adjustment process. That is far superior to the dial on the old one.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 02-08-2008, 10:58 AM   #10
Central , Mississippi
The only complaint I have with my P3 is no adjustment for the LCD viewing angle. The contrast adjustment won't allow me to see the display in the only place I could mount it. Functionally it's 100% better than my old unit, a Muffy? Puffy? heck I can't remember what I had before!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-08-2008, 10:09 PM   #11
Salem , Oregon
Images: 18
wire harness
Hi, uwe. The wire harness on the Voyager is part of the unit, not removeable. But the Prodigy harness would work with the P-3 controller.
2005 Safari 25-B
Old 02-08-2008, 10:17 PM   #12
Salem , Oregon
Images: 18
Hi, uwe. My wife wants to go back to San Clemente SB and boondock for a few days in the middle of the week. I don't know exactly when, but she wants to be near where Time & str8 were. Not a rally, but just us, or just a few friends. [very small group]
2005 Safari 25-B
Old 02-08-2008, 10:47 PM   #13
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
Looks like a nice unit! I like the display and menu settings.
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 02-08-2008, 11:59 PM   #14
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
We're going at the end of the month, arriving on the 29th , leaving on the 2nd, I believe. Please do join us!
We can't do mid week, both my queen and myself have carreers that keep us way too busy.
A severely disorganized, yet spontaneous Rally might be fun! Let's try!
Uwe
Brake Controller 1953 Flying Brakes & Brake Controllers 7 04-26-2007 02:17 PM
voyager brake controller vpurdy Brakes & Brake Controllers 3 01-15-2007 10:29 AM
Brake Controller (which one ) poorboycjs Brakes & Brake Controllers 3 07-25-2003 05:42 AM
brake controller JPAIRSTREAM Our Community 3 05-04-2003 08:38 AM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
