Old 08-11-2010, 06:15 PM   #1
1968 20' Globetrotter
fair oaks , California
Dumb Newbie Mistake #1
I moved my 68 GT (just bought one month ago) to my driveway so I could work on it for a few days. When I disconnected the hitch I forgot to undo the cable for the safety brake. Im not sure of the correct method of repair. Anyone care to enlighten me? If I cant get the parts to repair will I be able to move it or is it stuck here until I repair it. ThankYou.
dmcinfo is offline   Reply With Quote
Old 08-11-2010, 07:07 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
Plug the pin back in . . . fast . . . if you have a battery . . . or are connected to shore power with the inverter on line. When the pin goes in, it opens the circuit.
Old 08-11-2010, 10:24 PM   #3
Coundnt get the pin back in. What am I doing wrong?
Old 08-11-2010, 10:37 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
With the pin out for a long time time, your battery should be dead and you may have damaged you brake magnets. If you are very lucky your break away switch is not working and nothing is harmed. New switches are not very expensive.
Richard
Old 08-11-2010, 11:42 PM   #5
Dan@LED4RV's Avatar
Denton , North Carolina
power
With NO POWER going to the brakes,(No Battery, no Shore power, not hooked to the tow vehicle) you should be able to move the unit. That is if your going a short distance on a flat surface. If your on a steep grade you would not want to move it without brake.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 08-11-2010, 11:45 PM   #6
Break Away Switch
Fortunately, I connected to shore power right away so draining the battery isn't a problem. If I purchase a new break away switch is there anything I need to know about the install?
Old 08-12-2010, 06:21 AM   #7
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I'd try again to insert the pin. Never seen one that the pin would not go back into, albeit with some force necessary .... it's got some built-in friction and detents to keep it from falling out accidentally.
But with power to the 12volt system, either from battery or shore power, seems likely to me that your brake magnets will have been fried by now. They're designed for intermittent use, and you may have had them engaged since the time your pin came out ... Please have them carefully checked out by a pro.
AirsDream is offline   Reply With Quote
Old 08-12-2010, 06:24 AM   #8
1986 25' Sovereign
Plant City , Florida
I think your missing the part about burning up the brake mags. If not done so already these will be toast. You can order a new brakeaway switch from any of the vendors on the forums. If it were me I would cut the wire that leads to the switch one at a time so that you are sure that the brakes are off. Then you can cap the wires with wire nuts. When you recieve your new switch you will be able to solder the new one on.
Chris
BTW the old pins are a pain to put back in. on mine i feel like I am going to brake it.
ck21084 is offline   Reply With Quote
Old 08-12-2010, 08:36 AM   #9
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Break a way Switch 96-8375 [2009] - $26.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Use the enlarge function...it may answer some questions.
Old 08-12-2010, 08:56 AM   #10
Splitrock's Avatar
On my old switch, the pin was dry. I just applied some white grease and it slides right back in. It takes quite a pull to remove and an equal push to get it back in.
#2 for cutting the wires if all else fails.
Old 08-12-2010, 08:59 AM   #11
Kevin245's Avatar
Breakaway switches typically connect via 2 wires. Replacing one is fairly easy. Just remove the exisiting switch and wire the new one in it's place. Check the installation notes but usually the 2 wires are interchangeable.
Checking your brake magnet performance is important and as others have stated should be performed before heading out on your next trip. If replacement is required the task is fairly straight forward once the brake drums are removed.
Best of luck,
Kevin
Eleanor Roosevelt
Huge mistake-no 12v power? roblo101 Batteries, Univolts, Converters & Inverters 8 10-31-2009 07:31 AM
Dumb Newbie Questions ! btr Our Community 10 11-09-2008 07:27 PM
Dumb,dumb, and dumber rebel beck Electrical - Systems, Generators, Batteries & Solar 13 04-03-2006 11:11 AM
First real trip; real dumb mistake... myoung On The Road... 49 03-29-2006 07:37 PM
The 2500 Mile Mistake. Safari Tim Our Community 15 05-01-2005 04:50 PM
