Old 03-31-2013, 04:43 PM   #1
1972 31' Sovereign
1979 29' Ambassador
west monroe , Louisiana
Dragging brake pads
Electric over hydraulic brakes are dragging. Today, I removed one of the wheel's pads. My 'help' pressed the brake pedal and the piston did not move. However, when she operated the slide on my Kelsey controller, the piston moved out and I saw that the boot was torn. Hydraulic fluid flowed onto the concrete. I'm not sure if the breakage was due to the pads not in place? Also, I don't why the pedal didn't engaged the piston? There is one piston per caliper.
litlgeezer is offline   Reply With Quote
Old 03-31-2013, 05:18 PM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
All right, one piston per caliper. That describes a floating caliper. The caliper assembly can move or slide on its caliper mounting bolts. I think a pic might help. Is your piston metallic or non metallic? Again, if the caliper is not able to slide then it can drag, I bet most likely on the side opposite the piston. Are these Dexter's, Kodiak or unknown?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 03-31-2013, 05:20 PM   #3
1986 31' Sovereign
Miami , Florida
Most controllers sense deceleration and then apply a proportional signal to the brake actuator (or electric brakes) to match the trailer braking effort to the TV effort.
If you are not moving, no deceleration, no output.
Actuating the brakes manually with a pad removed sure could lead to what you experienced as the piston traveled well past where it normally would -- might have rolled a seal as well.
Mike
n2916s is online now   Reply With Quote
Old 03-31-2013, 05:24 PM   #4
The pistons can seize.
After 34 years you should overhaul the calipers.
The "O" rings and "BOOTS" are available.
Old 03-31-2013, 06:05 PM   #5
1972 31' Sovereign
1979 29' Ambassador
For some reason, I think Kodiak. Appeared to dragging on the side away from the piston, according to the position of the pads when I first removed the wheel.
Sorry, but I haven't yet learned how to paste pictures into my posts. Thanks.
Old 03-31-2013, 06:12 PM   #6
If the disc brakes are originals, the manufacturer is Ausco.
We still have some of the original parts.
Old 03-31-2013, 06:53 PM   #7
GCinSC2's Avatar
Now you're getting veteran experience with the older stuff. No old timer jokes intended Andy. The part config might be different, but principles still apply.
S/OS #001
Old 04-01-2013, 04:58 AM   #8
1972 31' Sovereign
1979 29' Ambassador
I guess you haven't moved to Texas yet. How can I tell who is the mgf of the brakes (or what type)? Are they labeled somewhere? I assume brake parts are listed on your website, but don't have time to look right now before work.
Old 04-01-2013, 06:15 AM   #9
All you can do is look for labels.
Or, send or post a photo.
We do not show all of our parts on our web site.
Old 04-16-2013, 05:18 AM   #10
1972 31' Sovereign
1979 29' Ambassador
Andy, Yes, I found the label Ausco. I will probably need to replace rubber boot and rings in each of four calipers. Also, want to put new disc pads on. I probably should replace the flex brake lines (they have a unique 90 deg end). One rotor will need replacement (or turned).
I am wondering if I should replace these out of production calipers with newer brands?
Old 04-26-2013, 02:45 PM   #11
1972 31' Sovereign
1979 29' Ambassador
I am wondering now, if I am going to be forced to abandon the existing Dexter actuator and hydraulic accessories and revert to electric brakes. I have exhausted all local brake shops, and apparently even Andy is having problems locating pads for the AUSCO brake calipers that are presently on the trailer. I wanted to stay with the system I now have, but it's camping time and I can't wait much longer. I guess I will be looking at $400 for electric assemblies with new hubs for my two new Dexter axles. Any suggestions will be appreciated.
Old 04-26-2013, 03:28 PM   #12
I am not having problems locating, but I am having problems getting it done in a reasonable timely manner.
We will in 2 to 3 weeks, once again have the original type disc brake pads.
10 minutes later.
Oops. Just got off the phone, placing the pad order.
We will have them in 10 days, or less.
Old 04-26-2013, 06:25 PM   #13
1972 31' Sovereign
1979 29' Ambassador
Thanks Andy.
Old 05-09-2013, 04:11 AM   #14
1972 31' Sovereign
1979 29' Ambassador
Andy, What's the latest word on the brake pads ?
