Old 12-15-2009, 04:20 PM   #1
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Donít Forget to Adjust Your Airstream's Brakes
Our last camping trip of this season saw The Mighty Burb doing ALL the braking during some fairly steep, downhill grades. While this truck is an extremely capable tow vehicle, it was not happy. But it rose to the challenge, and kept us safe. I was not happy either, as I had "just" replaced the axles complete with new brakes.
Troubleshooting after our slow return, I found that time flies, and I had just forgotten that my Airstream's brakes had accumulated too many miles on them without adjustment. The complete tale can be read here.
Don't let complacency sneak up on you like I did. Adjust electric trailer brakes after no more than 6000 miles of travel.
Tom
Old 12-15-2009, 04:52 PM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Thats a good reminder Tom.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 12-15-2009, 05:05 PM   #3
wolverine's Avatar
2005 31' Classic
Sunrise Beach , Missouri
Another good reason to consider installing Dexter NevRJust brakes the next time you need brake service. Self adjusting brakes eliminates this potential risk.
These brakes are now available as a complete backing plate replacement for $50 each which is less expensive than replacing existing lines, magnets, etc.
wolverine is offline   Reply With Quote
Old 12-15-2009, 05:11 PM   #4
Kevin245's Avatar
We...I mean me...Pull a bearing PM every Fall. As suc the brakes get checked and adjusted while the hubs are off. Steep grades and poor trailer braking me.
Thanks for the reminder.
Kevin
Eleanor Roosevelt
Old 12-15-2009, 09:01 PM   #5
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I pull the wheels and adjust every spring as I put about 15-20k miles on the trailer each year. I have a straight shift diesel with an exhaust brake and I get teriffice mileage on the trailer brakes as the engine does most of the normal braking, specially on off ramps and downgrades.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 12-15-2009, 09:28 PM   #6
munimula's Avatar
1993 34' Excella
1962 16' Bambi
New Haven , Connecticut
Last month I inspected my brake magnets and found that they were so worn the copper spooling was exposed. Had to replace all six magnets at $35 a magnet. Trailer brakes are now working perfectly.
Morrison's Airstream Page
munimula is offline   Reply With Quote
Old 12-16-2009, 05:34 AM   #7
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Do you know if these brakes are standard on new axles? I just put new Dexters on my '73 and don't recall any mention of this when I ordered them. I did have to adjust my brakes during installation.
www.nesa.org
Air No. 6427
Old 12-16-2009, 07:29 AM   #8
munimula's Avatar
1993 34' Excella
1962 16' Bambi
New axles come with new brakes. you are good to go for a few years on the brake front. that does not preclude you from greasing the bearings every year or so depending on use.
Old 12-16-2009, 08:03 AM   #9
jordandvm's Avatar
2017 28' International
Western , Oregon
Images: 58
Thanks for the heads up on this. I recently experienced problems braking going down steep passes over the Rockies and had some front end wobble in the TV. I replaced the front rotors and will test them on our trip south in January. In the mean time I will have the trailer brakes inspected before I go and give you a report on their condition. I suspect they are partly to blame for my original problem. This is the thread relating to my problem and people's helpful responses http://www.airforums.com/forums/f439...des-57926.html
Jim & Cheryl
2017 28' Signature CCD
2017 GMC Denali HD Crew Cab 4x4
Blue Ox Sway Pro Hitch
WBCCI #3538
jordandvm is offline   Reply With Quote
Old 12-16-2009, 10:40 AM   #10
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Does anyone know if the new backing plates work with the screw in lug studs (not bolts) that the older trailers use? My current hubs don't use lug nuts....
Thanks!
Marc
Old 12-16-2009, 10:56 AM   #11
Thanks!
Marc
The style hubs you have, has nothing to do with the electric brakes, either manual or self adjusting.
Old 12-16-2009, 02:12 PM   #12
Got gandkids?
Agreed. What I'm asking is:
Do ALL NEW DEXTERS come with this NevRJust feature?
I've not heard of this specific feature on Dexter axles before.
www.nesa.org
Air No. 6427
Old 02-17-2010, 04:49 PM   #13
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I just had my bearings done and brakes adjusted, and when I got home and parked it I stepped out and could smell something which I associate with brakes. My husband thought so too. I watched him back it into the carport and I could hear the brakes hum when activated, they seemed to be behaving normally, and it felt normal on the drive home. I wonder if what I was smelling was just because they had adjusted them and maybe they were dragging a bit or something? Should I be concerned or is that normal?
Stephanie
Old 02-17-2010, 05:00 PM   #14
TomW's Avatar
1967 26' Overlander
Maybe, and no
Originally Posted by Stefrobrts View Post
.. Should I be concerned or is that normal?
Your description sounds like your brake shop set the brakes up a little too tight.
The proper adjustment of manual-adjust brakes is apparently somewhat subjective. Some mechanics feel the shoes need to drag more than other mechanics do.
At this point, you have two options. Jack one side of your American Classic up, and spin a wheel and "be one" with the amount of effort. Decide for yourself if it is too much effort.
Option two is to call the boyz up at the shop, and determine if they share your concern.
Tom
Letter to Don Shafer & IBT Buttercup WBCCI Forum 35 04-23-2012 05:46 AM
Adjust door flmgrip Doors & Locks 5 09-04-2009 06:53 PM
What is the right way to adjust sway bars toastie Hitches, Couplers & Balls 57 08-24-2007 07:40 AM
I am going to attempt to adjust my window ipso_facto Windows & Screens 5 11-08-2003 09:08 AM
