Old 02-17-2010, 05:26 PM   #15
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Rivet brake smell
Originally Posted by Stefrobrts View Post
I just had my bearings done and brakes adjusted, and when I got home and parked it I stepped out and could smell something which I associate with brakes. My husband thought so too. I watched him back it into the carport and I could hear the brakes hum when activated, they seemed to be behaving normally, and it felt normal on the drive home. I wonder if what I was smelling was just because they had adjusted them and maybe they were dragging a bit or something? Should I be concerned or is that normal?
If you smelled the brake linings (unless you did a panic stop or fast deceleration from 60mph just before pulling in), you should have the shop check to see if they are to tight. Some drag is good, to much and they will heat up and cause the burning smell you may be experiencing.
Better safe than sorry in bluing the drums/discs.
arcamedies is offline   Reply With Quote
Old 02-18-2010, 11:47 AM   #16
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I called them and they said to bring it back in to check it out. They said they shouldn't be dragging at all. So one more trip to the shop...
Stephanie
Old 02-18-2010, 01:42 PM   #17
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Originally Posted by Jim & Susan View Post
Agreed. What I'm asking is:
Do ALL NEW DEXTERS come with this NevRJust feature?
I've not heard of this specific feature on Dexter axles before.
Hi Jim,
The Nev r adjust brakes are recent product. I am pretty sure that it is not, even now , standard on all Dexter axles.
I do know that they are standard on 2010 A/S classics, but I don't know about the rest of the lines. My trailer also came standard with Dexter's Nev R lube hubs.
Here are a couple links.
http://dexteraxle.com/i/u/1080235/f/...djust_4-09.pdf
http://www.dexteraxle.com/nev_r_lube_bearings
http://dexteraxle.com/i/u/1080235/f/...rings_2-08.pdf
regards,
Ken
Letter to Don Shafer & IBT Buttercup WBCCI Forum 35 04-23-2012 05:46 AM
Adjust door flmgrip Doors & Locks 5 09-04-2009 06:53 PM
What is the right way to adjust sway bars toastie Hitches, Couplers & Balls 57 08-24-2007 07:40 AM
I am going to attempt to adjust my window ipso_facto Windows & Screens 5 11-08-2003 09:08 AM
