Old 04-04-2013, 10:24 AM   #81
Images: 59
Originally Posted by Aage View Post
I believe it's called "big stackies of woodish thingies"
That sounds very Scottish.
Close enough.
Old 04-04-2013, 11:52 AM   #82
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Originally Posted by markdoane View Post
I guess you should educate us. What is cribbing called in the UK?
I was going to say that I have no idea, but Aage came in with a better answer first!
Steve; also known as Mr UK Toad
"You can't tow that with that!"
https://sites.google.com/view/towedhaul/home
MrUKToad is offline   Reply With Quote
Old 04-04-2013, 11:57 AM   #83
MrUKToad's Avatar
Chatham , Ontario
Ten minutes research and I find that it's known as "Dunnage" in the UK (see earlier reply). Nope, never heard of it; "big stack of woody blockie thingies" works for me.
Old 04-04-2013, 06:24 PM   #84
1969 18' Caravel
Augusta , Georgia
Okay, so I have derailed a thread or two, but this one really slid off the track...and I love it! I'll be happy to tell my husband what to stack under the bumper and I bet he still won't have a clue after I use all the different words for big stickies of woodish thingies! However, we will stack something under there to prevent me from becoming a pancake.
Caroline
1969 Caravel "Sylvie"
moderninthesouth.blogspot.com
Modern South is offline   Reply With Quote
Old 04-04-2013, 07:25 PM   #85
altnbndr's Avatar
1967 17' Caravel
1968 22' Safari
Sacramento , California
Images: 11
Dunnage or Cribbing?
In my work, commercial construction sheet metal (high rises and hospitals) we use both terms but they mean different things. "Dunnage" is the term used to describe wood or other non-structural items used to keep materials up off the ground to keep it out of the mud or dirt and to be able to easily get a forklift or hoisting sling under it for the movement of materials around the job site. Usually dunnage is scrap or trash of some sort which has a low cost $$$ or free found on site. Pallets and skids are considered dunnage which are made of low grade materials.
"Cribbing" is the term we use when referring to structural materials used to stack under equipment or other heavy items on the job where there will be crews working under it to protect them from being crushed in case the load shifts or becomes unstable. Working in California we have to always be aware of the possibility of a major earthquake that would cause a load to shift and prepare for it to protect our crews using "cribbing". Cribbing has to be structurally rated materials such as I-beams, tube steel, oak or other hard woods that are rated to support the load. Cribbing is never something just found on site and is purchased or obtained for a specific purpose of protecting our crews. Cribbing is expensive $$$$$$$$ but can usually be saved and reused many times.
As long as you use something as a redundant back up to the jack stands you will be ahead of the game. NEVER use cinder blocks, concrete , or bricks because they may shatter if a sudden concentrated load is placed on them.
Changing the axle on a single axle trailer is probably the most dangerous job to perform on any Airstream but can be done safely if you just plan ahead and take your time. "Don't be in a hurry to get hurt"
altnbndr
altnbndr is offline   Reply With Quote
