Old 07-11-2006, 01:38 PM   #15
silverback's Avatar
2006 28' Safari SE
Sierra Vista , United States
Bridger
Jonathan is correct. I check/adjust my settings before every tow. I set my Prodigy to ~5.5 or 5.6 and use level two boost (needed with Hensley hitch). Your numbers will likely be different.
-KL
4CU Charter Member
silverback is offline   Reply With Quote
Old 07-11-2006, 02:18 PM   #16
1972 25' Tradewind
Wentworth , South Dakota
If I were you I would look into why this guy hates you! Remember just because your paranoid don't mean some one isn't trying to kill you. Good Luck in your travels.
Danetree is offline   Reply With Quote
Banks exhaust brake for Dodge Ram wflorencejr On The Road... 9 10-15-2005 08:26 PM
Brake Controllers smily Brakes & Brake Controllers 6 10-02-2002 06:12 AM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
