Old 07-20-2014, 09:01 AM   #1
2010 16' International
kittery , Maine
Do I grease the track the brake magnets ride on?
I'm doing brake maintenance on my 2010 Bambi.
The magnet rides on a track that goes through the center of the magnet.
Is this track supposed to be greased?
amm3824 is offline   Reply With Quote
Old 07-20-2014, 09:35 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
You do not grease the parts used to activate the brakes.
The most you want to do is put the smallest amount of Lithium on the contact points where the brake shoes ride against the backer plate.
Grease will migrate when heated and cover everything in time.
2004 Excursion 4x4
Old 07-20-2014, 12:08 PM   #3
NO, NEVER.
Old 07-20-2014, 12:59 PM   #4
1981 31' Excella II
New Market , Alabama
The only thing that should be lubed is the adjuster screw. If this screw freezes adjusting the brakes is near impossible. I use an antisieze paste you can get at any auto parts place. Best to remove the screw mechanism and put a little of this paste on the threads and on the screw side of the little fork shaped deals that press against the shoes.
Perry
Brake magnets kingfisher24 Brakes & Brake Controllers 11 05-18-2011 10:22 AM
Brake magnets 1976 Sovereign Splitrock Brakes & Brake Controllers 2 07-31-2010 01:29 PM
To grease or not to grease Grand Master Hitches, Couplers & Balls 16 04-19-2009 01:45 PM
Grease on brake magnets lbrodsky Brakes & Brake Controllers 43 11-25-2006 07:06 PM
Need a couple of old brake magnets Excella CM Brakes & Brake Controllers 1 07-02-2006 07:47 AM
