Old 10-05-2011, 03:32 PM   #1
1981 31' Excella II
New Market , Alabama
Do Henschen Axles Use Standard Backing Plates?
I was wondering do Henschen axels use generic trailer brake parts and backing plates etc. or are they oddball?
Perry
Old 10-05-2011, 03:44 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Generic.
Bill
Perry
Just my personal opinion
Old 10-05-2011, 04:46 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Perry
You can get them at any trailer or RV place. If you are replacing parts, you will need to know if you have round or oval magnets. The round were the old school stuff, the ovals are the modern stuff.
Old 10-05-2011, 04:47 PM   #4
1981 31' Excella II
Can you not upgrade to the ovals?
Perry
Old 10-05-2011, 05:09 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
If you purchase loaded backing plates, you will get the new oval magnets. Loaded backing plates is much cheaper than replacing parts.
Bill
Perry
Old 10-05-2011, 05:15 PM   #6
Perry
The old style 12 inch electric brakes used round magnets.
The new style 12 inch electric brakes use oval magnets, that offer more stopping power.
Changing out the new backing plates for the old, has no drawbacks, as replacement is a piece of cake.
Old 10-06-2011, 05:54 AM   #7
1981 31' Excella II
What happens if you put an oval magnet in an old assembly?
Perry
Old 10-06-2011, 07:46 AM   #8
Perry
DON'T.
You will regret it, besides the magnets cost almost as much as a backing plate.
Old 10-06-2011, 09:07 AM   #9
1981 31' Excella II
I assume the stock brakes are 12" diameter by 2" wide or 2-1/2" wide? I also assume that the bearings are generic as well.
Perry
Old 10-06-2011, 11:25 AM   #10
Perry
The brake shoes are 12" x 2"
The inside bearing is 25580
The outside bearing, depending on the hub, was LM 67048 and is now 15123.
Old 10-06-2011, 08:32 PM   #11
1981 31' Excella II
Ok well I got the wheels off tonight. One of the 4 drums looks questionable. There is a pretty good sized groove in it. It may turn down ok but I think there will still be some groove left before it goes .090 over. So I may need a drum. The brakes shoes are shot on all 4 wheels. The bearings and spindels look ok. None of the bearings were siezed or stuck to the spindles. My axels seem to still have some flex left in them because the wheels dropped a good bit when I jacked it up. They have definately not solidified. I have not checked the bearings real close yet. I bet the drum is not going to be cheap if I can find one. I can put it back for this trip but I would prefer to have it working properly.
Perry
Old 10-06-2011, 08:43 PM   #12
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
When these drums are turned do you need to turn the magnet contact area?
If so, I assume it takes certain type of equipment to cut???????
'77 Sovereign Intl 31' CB
Old 10-06-2011, 09:03 PM   #13
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
What is your definition of cheap? They are generic and available at Camping World (not the cheapest place) or any trailer supply company.
Bill
Perry
Old 10-06-2011, 10:09 PM   #14
A good machine shop can turn the drum brake surface and the "armature plate", the surface that the magnet rides on, as it must be smooth for best perfomance.
Texas Year of Manufacture License Plates Bambi_Bandit Title, VIN & Registration 15 06-18-2011 10:52 PM
Henschen replacment axles JDL Axles 14 02-04-2011 01:41 AM
