Old 08-14-2012, 11:48 AM   #1
1981 31' Excella II
New Market , Alabama
Disk brake conversion - Who is best and long term parts availability?
I am trying to make a decision about putting disk brakes on my trailer. I am tired of messing with drum brakes. However, if I am not careful I will spend $1000 and still have problems with substandard parts and parts becoming obsolete because the fly by night Chinese company decided to go out of business etc. I would like a setup that uses off the shelf car calipers and pads so I can get parts 20yrs from now.
Can anyone give me feedback on experiences you have had with different disk brake systems.
Here is a short list of trailer disk brake manufactures.
Kodiak, Tie Down, UFP, Titan, Carlisle, Dexter etc.
Perry
Old 08-14-2012, 12:02 PM   #2
2006 30' Classic
Milton , Florida
Dexter Disc Brakes
Originally Posted by perryg114 View Post
... I would like a setup that uses off the shelf car calipers and pads so I can get parts 20yrs from now.
Perry
My unit has the Dexter disc brake system, including brakes, E/H actuator, and axels. I have no complaints with the system as it currently stands, but I had to correct several design and installation issues that Airstream created when they installed the system.
The Dexter system does not use OEM automotive brake pads.
My personal preference is for hydraulic disc brakes, and I would not have a travel trailer with electric brakes.
Have you considered talking with some of the shops that sell and service large horse trailers in your area? They could do such a conversion. Otherwise, talk to J. D. Sanders in Alachua, Florida.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 08-14-2012, 12:30 PM   #3
1981 31' Excella II
I talked to trailer parts superstore and they recommended Kodiak disk brakes and calipers with a Dexter Actuator. The guy told me the Kodiak brakes were an old Chevy design but he could not tell me what year and model they came from. This would be nice if it were true because the quality for Automotive stuff is going to be better not to mention the availability factor. These are the guys I talked to. Their prices seem to be a little better than etrailer.com
Electric, Hydraulic & Air Trailer Brakes at Trailer Parts Superstore
Perry
Old 08-14-2012, 01:38 PM   #4
Perry
Our experience has shown that the Kodiak brakes with the Carlisle actuator, works the best.
Old 08-14-2012, 04:24 PM   #5
1981 31' Excella II
Well it seems that the Kodiak brakes are the way to go then.
Andy, what is it about the Carlisle Actuator that you like over the Dexter?
I did find out that the claim that the Kodiak Pads were a Chevy part is true. The models that fit the trailer are in the instructions and in their catalog.
Perry
Old 08-14-2012, 04:47 PM   #6
Greg@AirLA's Avatar
1960 24' Tradewind
Riverside , United States
If you have the aluminum wheels that were pretty much standard on that year they will not fit with the Kodiak brakes, OK with the Dexter.
Greg
Greg Paulsen
Greg@AirLA is offline   Reply With Quote
Old 08-14-2012, 04:49 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Perry
This is the setup we use at the shop for disc brake conversions.
The pads are for a 1986 Chevrolet Celebrity without heavy duty brakes.
Napa has a part number of PD7070AR.
Old 08-14-2012, 04:56 PM   #8
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Good job, Perry. I'd want to also check with TUSON [DIRECLINK] about their componentry and ask about the release date of their trailer brake anti-lock module (to be sure all components are working together; am assuming you are interested if for no other than FYI).
The heaviest '86 Celebrity I could find appeared to be about 3,300-lbs with driver & full fuel. Assuming a 60-40 FF/RR weight bias, that FA would have been carrying around 1,000-lbs per 14" 185-series tire. I could find no GVWR ratings, much less Axle Weight ratings.
I couldn't find the NAPA # referenced above, but did find (for light duty brakes):
RAYLOC TRu-Stop TS TS7070BM
NAPA Cross Reference is:
Buick Century 1982 - 1989
Buick Skylark 1980 - 1985
Chevrolet Celebrity 1982 - 1989
Chevrolet Citation 1980 - 1985
Oldsmobile Cutlass Ciera 1982 - 1989
Oldsmobile Omega 1980 - 1984
Pontiac 6000 1982 - 1990
Pontiac Phoenix 1980 - 1984
EBC Rotors has some "good looking" pads, but the question would be the change in pad size from LD to HD on the Celebrity.
Old 08-14-2012, 05:00 PM   #9
Perry
Less reported trouble.
Old 08-14-2012, 05:31 PM   #10
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Brake Performance has LD specific choices across a range.
Gonna need to get you a G-Tech meter or similar and measure before/after braking G-forces & distances, huh?
Old 08-14-2012, 05:37 PM   #11
1981 31' Excella II
Greg do you mean the Kodiak brake calipers will hit the inside of the rim? I assume you have had this problem? Anymore information you can share on this? I suppose I could order a kit for one wheel and see what happens and send it back if it won't fit.
Perry
Greg
Old 08-14-2012, 05:38 PM   #12
Well Preserved
1993 21' Sovereign
Looks like the part number has been updated slightly, Napa probably changed brake vendors.
HD pads will not work. They look similar, but will not fit.
Old 08-14-2012, 05:55 PM   #13
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Good FYI, thanks (as I also have this on "the list").
Old 08-14-2012, 06:01 PM   #14
1981 31' Excella II
I asked Kodiak to send me some CAD drawings or a 3D model so I can draw up the whole thing and see what the problem is. A spacer maybe required to make it work. I am running slightly oversize tires as it is and I am not sure how much farther out the tire can go before it hits the fender.
Andy do you have any knowledge of this problem with the calipers not fitting with the stock aluminum rims?
Perry
