Old 01-28-2010, 07:43 AM   #29
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by 2airishuman View Post
another more complicated but no less REAL issue is towing with drums BEHIND modern vehicles...that have BIG POWERFUL disc brakes (cayenne, armanda, x5, m/g class merc')...because the MISMATCH between the trailer brake performance/characteristics and the TV... can and does cause problems.
i've seen this firsthand and talked with several 'streamers... who had issues when the trailer wasn't UP TO the TV in terms of braking performance...
Yup. No matter what I do to modify drums they STILL won't be a good match for the TV. I want the trailer to react to my inputs predictably, NOT questionably.
The mantra I learned was that being lane-centered was what mattered. Alpha & Omega. (A point of departure for thinking through scenarios). And it was dependent on steering control . . I don't want the brakes to have an effect on moving my centerline (due to plenty of reasons we could cite); I want them to do one job spectacularly well, and that only. Any changes in direction relative to travel need to be driver-initiated . . and the most powerful trailer brakes to minimize input time/force by the driver is conducive to that goal.
Old 01-28-2010, 07:59 AM   #30
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Still a drummer...
My experience only...
When we got the haha we also started using the Tru-control, the improvement in brake operation was stunning.
Do not underestimate the importance of a quality brake controller properly set-up.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 01-28-2010, 08:41 AM   #31
Brakes
Most everyone agrees that disc brakes that are working properly on the trailer, does indeed shorten the stopping distance of the tow vehicle, short of sliding the tires.
The positive cause of that improvement, is that the trailer brakes provide more stopping power than it needs for itself.
Even the old original Airstream Excella-Vac disc brakes easily performed the same task.
But, some still love electric brakes, feeling that they are satisfactory for their needs.
Some like satisfactory, many like outstanding.
Some still like stick shift instead of automatic.
As always, to each his own pleasures and expectations.
And so it is.
Old 01-28-2010, 08:56 AM   #32
Thumbs up
Rite on Andy.... I do expect many pleasures...
PFC
"Tahawus"
RLC
John Prine
Old 01-28-2010, 11:57 AM   #33
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Originally Posted by 4slice View Post
I have the Carlisle actuator, which has worked well for me for seven years now. I do notice some lag time (a rather significant two seconds or so) while the pump pressures up.
I hear this complaint from time to time. Two seconds is far too long to be waiting for brakes, and the cause should be investigated. People often blame the actuator, but in my experience it's usually NOT the cause of the problem.
Two things to check:
1. Check for proper fluid level in the actuator's reservoir.
2. Bleed the brake lines. Tiny air bubbles in the lines are very common, and easily rectified by bleeding the brakes. Unfortunately, I've discovered that even certain Airstream service centers are not 100% reliable at bleeding the brakes properly during installation. You can do it yourself with a few minutes of instruction, an assistant, and a brake bleeder wrench.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 01-28-2010, 05:30 PM   #34
2007 30' Classic S/O
Somewhere , South Carolina
Very interesting post series, especially for this Newbie.
I had no idea that my Actibrake was NLA, I'll be watching for members recommendations for replacement actuator sytems as this pogresses. Yes, I have only towed it once so far but the braking seemed confident, controlled and consistant. I do have the option of shifting down to lower gears, one of the pluses of manuals. I watched the installation DVD for the system and one big advantage is the power bleeding that the Actibrake offers. I get involved in other bleeding challanges, this one looked really simple.
The only thing I wondered about with my Actibrake is the delay on de-energization. It lasted just a split second or so, but you can feel the trailer still applied after releasing the foot brake.
Any comments?
Andy, I do like your quartet, are you the drummer, singer or a picker?
2007 Classic 30' SO
2005 Dodge Ram 2500 5.9L Cummins 6 Speed
1997 Dodge Ram 3500 5.9L Cummins 5 Speed
GCinSC is offline   Reply With Quote
Old 01-28-2010, 07:10 PM   #35
Any comments?
The Carlisle actuator seems to be the best available at this time.
I would suggest that you double check your brake controller for proper operation.
None of the above.
Old 01-28-2010, 08:49 PM   #36
4slice
4slice's Avatar
1977 31' Sovereign
Chase , British Columbia
Carlisle actuator lag time...
Rluhr, last summer the hitch shop (actually a spring/axle shop) flushed the entire system, put in new brake fluid and bled it. The lag was still present as before. I've gotten used to applying the hand controller two seconds before I anticipate having to use the brakes. That's okay for traffic lights, but not much help if a moose were to trot out of the ditch, at night, in the rain, on a mountain road....
4slice is offline   Reply With Quote
Old 01-28-2010, 09:03 PM   #37
If Actibrake was still in business, they would have offered some assistance to solve that delay problem.
In the meantime, your best bet would be to replace the actuating unit.
Better to be safe, than sorry.
Electric over Hydraulic/disc brakes Phil Gobie Brakes & Brake Controllers 12 10-13-2017 02:03 PM
1977 Hydraulic Disc Brakes? Atlantica Brakes & Brake Controllers 22 11-20-2007 09:49 PM
Hydraulic disc brakes failed Gator1 Brakes & Brake Controllers 1 03-13-2007 09:19 PM
Disc Brakes?...2005 Classic Limited w/Slide TomR Brakes & Brake Controllers 2 10-05-2006 08:46 PM
Kodiak Hydraulic disc brakes thenewkid64 Brakes & Brake Controllers 1 07-06-2004 10:48 PM
