Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 09-25-2007, 08:29 PM   #1
Brad Hunt
Profile:  2007 25' Safari SS SE
Alton , Illinois
disc vs drum brakes
I bought an 07' 25' Safari, will braking improve if I upgrade to disc brakes? How much will it improve? Necessary on a 25 footer? Need a new brake controller? If you think it is a waste on a 25' you won't hurt my feelings because I want to know. My daily driver/TV is an 05', 2wd, 3500 Dodge diesel if that helps any. Thanks, Brad. PS I was going to take it to the AS factory to have brakes installed but only if its a real improvement
The "Ann Rutledge"
Brad Hunt is offline   Reply With Quote
Old 09-25-2007, 08:40 PM   #2
Gen Disarray
Gen Disarray's Avatar
Profile:  1968 24' Tradewind
Lawton , Oklahoma
I considered disc brakes when I replaced the axles. Consensus at the time was, yeah they are nice, but not worth the extra money unless you have money to spend.
Rodney
Experience hath shewn, that even under the best forms of government those entrusted with power have, in time, and by slow operations, perverted it into tyranny. - Thomas Jefferson
Visit my photography page at:http://www.pbase.com/professor_chaos
Gen Disarray is offline   Reply With Quote
Old 09-25-2007, 08:40 PM   #3
Gunnyusmc
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Disc vs Drum
I have Stainless Kodiac on my 25' Safari FB/LS/SE and it is the best up grade.
I had drum on my 24' and the braking is so much better, that I would never go back too drum.
Don
Gunnyusmc is offline   Reply With Quote
Old 09-25-2007, 08:46 PM   #4
2airishuman
2airishuman's Avatar
Profile:
the discs are a definite improvement in stopping distance (reduced by 50%) and fade...
they are easier to service with fewer moving parts....
and hub balance is LESS of an issue....
i've got 45k on the 6 discs and won't have anything else.
otoh drum brakes work and are widely used.
so i think it depends some on driving style and towing expectations and other issues....
i really really like the kodiac/actibrake combo....
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 09-25-2007, 09:07 PM   #5
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Disc brakes compared to electric brakes, is not "a real improvement," it's a huge one, even for your 25 footer.
Yes the initial cost may sting, but the many miles of your towing will be far more rewarding, knowing that you have the "ultimate" in travel trailer brakes.
Towing, comfortably and with peace of mind knowing you have the best, will add many smiles to your face, and your family's too.
Maximizing safety, never needs an apology.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 09-25-2007, 09:13 PM   #6
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
I couldn't disagree more, Rodney.
Uwe
Old 09-25-2007, 09:24 PM   #7
Goin camping
Profile:  2007 25' Safari FB SE
valencia , California
Disc V. Drums
IMHO, Drums have worked great for decades. However I like the idea that with discs the trailer can stop the truck. The info from the disc mfg's say they improve stopping distance by %47 to %50 and eliminate brake fade.
Do you need discs? Probably not. Should you have discs for the safty factor alone? I think so. Installed discs for your model ( I priced it earlier today.) will be in the nieghborhood of $2,800.00 thats less than the cost of minor to moderate front end damage if you don't stop in time. Pretty cheap when you look at it that way.
Today I got a cost of $1,600.00 for the parts to do it myself. I'll check other sources to see if anybody is selling it for less.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Goin camping is offline   Reply With Quote
Old 09-25-2007, 09:52 PM   #8
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
On my 31 is is a must! I have scared a few people behind me when I have to stop quickly. It does stop quickly. I trailer is tugging on the truck. If I remember correctly. I have 27,000 lbs of stopping force on 17,000 lbs of weight. Worth thier weight in gold!
Michelle
If you think you are having a bad day go to the hospital and visit the children.
Sarah
Ruby, (05 BMW R1200RT)
Daisy, (06 Turbo Diesel F-250 w/Tow Command, the perfect TV)
Butter Cup, (06 Classic 31 w/dinette, solar)
45,000 miles in two years!
http://Michelles-Adventures.US
Old 09-25-2007, 10:09 PM   #9
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Offer still open?
Hi, I'm still open for those people wanting to get rid of those crappy drum brakes on their new Airstream trailers. If you have to have the disc brakes on your new trailer with 12" drums, UPS the new drum brakes to me, [for the UPS charge] I could use a spare set. Although there has been some problems with the new disc brakes, there is no doubt that they stop somewhat better than the drums. If you tend to overload your trailer, have a marginal tow vehicle, or like to travel fast, by all means convert to disc brakes.
Not all of us are "Airstream Millionaires" so I would advise some of you out there to wear out your drums first before spending $3,000.00 for something you Want , not Need. I don't have that kind of money in my cookie jar either. [actually I don't even have a cookie jar]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 09-25-2007, 10:10 PM   #10
Brad Hunt
Alton , Illinois
Well that settles it, even 10-15% is worthwhile but 50% is much better than I hoped for. What about brake controllers? I would like to have a controller that will handle the tandem axle and the triple axle if I ever decide to buy a nice used 34'. I have one of those Dodge diesels that gets insanely good fuel economy so I just figured to buy the right controller and be done with it because the Dodge stays.
The "Ann Rutledge"
Old 09-26-2007, 08:16 AM   #11
thecatsandi
Missoula , Montana
My Ford tow comand (tekonsha) and prodigy works well with the actibrake acuator.
You need to find out which one they are using.
Michelle
Sarah
Old 09-26-2007, 08:48 AM   #12
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
There's less to go wrong and it's much eassier to inspect discs. Get 'em!
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 09-26-2007, 09:33 AM   #13
rluhr
Commercial Vendor
rluhr's Avatar
Profile:  1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Cool Love those disc brakes!
I have to chime in on the vote FOR disc brake upgrades. Drums are OK for the lighter trailers, but for a 30-footer that weighs in around 7500-8500 lbs, the four 12" drum brakes seemed lame to me. I got tired of the trailer pushing me after the brakes faded on a hard stop.
The difference with discs is almost unbelievable. The trailer stops the truck, even on major (8-10%) downgrades.
I got mine at Roger Williams Airstream in Weatherford TX, and can heartily recommend them if you live in that area. (I'm sure Inland RV and the Airstream factory can also do a good job on the upgrade.)
One word of caution: the OEM organic brake pads that came with our upgrade kit lasted less than 10k miles. Semi-metallic pads seem to be lasting much longer, and I've been told ceramic pads really last a long time.
We use the same Tekonsha Prodigy brake controller that we used with the drums. It works very well.
(ROBERTSUNRUS: My old drums are still at Roger Williams Airstream in a big pile with all the others. Ask David Tidmore if you can have 'em, with my compliments.)
Name:	drum brakes.jpg
WBCCI #9990 | VAC | Full-timer | AIRSTREAM LIFE magazine | Tour of America weblog
rluhr is offline   Reply With Quote
Old 09-26-2007, 09:58 AM   #14
uwe
418
uwe's Avatar
Images: 40
They also run much more balanced than drums, resulting in less vibration, and a much better balanced hub/wheel assembly.
Uwe
Disc vs Drum Brakes? Thrift Brakes & Brake Controllers 39 08-11-2007 12:19 PM
hot drum--help ASAP please Zeppelinium Brakes & Brake Controllers 23 08-09-2006 10:28 AM
Need easy way to take brake drum off..>> Mrcrowley Brakes & Brake Controllers 18 05-23-2006 08:44 PM
Need Help –Brake Drum HOT! Mookie Brakes & Brake Controllers 12 05-21-2005 09:36 AM
Hadco Brake Drum rfcjr Brakes & Brake Controllers 1 07-25-2004 04:18 AM
