Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 07-22-2008, 09:10 PM   #71
hookedonclassic
hookedonclassic's Avatar
Profile:  2006 34' Classic
Fond du Lac , Wisconsin
Originally Posted by johnbaker View Post
HOOKEDONCLASSICS,
I you should contact Actibrake with your serial number and see if your Actibrake could have an issue that you should be aware.
Yes, Brakesmart is not on Jacson Center's list but it's not made anymore. I never had any issue with it Brakesmart on my Excursion and still use it!
I hope you find the answer to your issue, post the resoultion.
John Baker
John: I called Actibrake today and described my situation. They didn't think it was an issue with the computer board (2004 issue). One likely cause could have been a poor ground wire with either the TV or AS. Although I wasn't talking to their expert expert, the fellow was very knowledgable. They don't have Brakesmart on their approved controller list for the Actibrake system. They do extensive testing with various brands and the ones that they say work the best are Hayes Genesis, Prodigy and Primus/PE now pretty much in that order. They have done some testing with Hensley's TruControl with out any problems but not extensive testing yet. He did comment that the Voyager doesn't work at all with it.
So, since the Brakesmart seems to be working for me now and it sounds like that is the case for others as well, I think I will not replace anything yet. If I do, I would probably go with the Genesis based on what I know at this point. The Genesis is also the one that the factory installs. As Actibrake said, it's the one that seems to work best with the Actibrake computer.
I think Brakesmart is still available through Dr. Performance. At least it's on their website yet.
Rich
2006 Classic 34 Front Lounge
2004 GMC Duramax CC SB
Hensley Arrow
WBCCI #5401
AIR #4489
hookedonclassic is offline   Reply With Quote
Old 07-23-2008, 03:23 PM   #72
johnbaker
johnbaker's Avatar
Profile:  1978 Argosy 30
Dallas , Texas
Images: 11
Hookedonclassic,
It sounds like you found someone that didn't give you the run-around.
Good luck to you, John
John Baker
1978 Argosy 30
Hensley
Excursion
johnbaker is offline   Reply With Quote
Disc vs Drum Brakes? Thrift Brakes & Brake Controllers 39 08-11-2007 01:19 PM
hot drum--help ASAP please Zeppelinium Brakes & Brake Controllers 23 08-09-2006 11:28 AM
Need easy way to take brake drum off..>> Mrcrowley Brakes & Brake Controllers 18 05-23-2006 09:44 PM
Need Help –Brake Drum HOT! Mookie Brakes & Brake Controllers 12 05-21-2005 10:36 AM
Hadco Brake Drum rfcjr Brakes & Brake Controllers 1 07-25-2004 05:18 AM
