Old 11-11-2019, 05:09 AM   #21
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Al and Missy View Post
Rich,
I have the Kodiak single piston floating calipers. I have observed little to no difference in the tendency for the TV/TT combination to roll on a slight incline when the brakes are released.
Al
Ok, great. Be aware, the math for a floating single caliper is the same as a two piston. The pressure acting on the caliper half of the fluid chamber pushes the caliper and the piston equally ( minus friction on the knuckle and pins), so your thought of my doubling my math is an over sight. Be sure those slides and pins are clean.
-Rich-
Old 11-11-2019, 09:22 AM   #22
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
It's a simple concept, and I totally missed it. Thanks for pointing it out. The rigid caliper body translates the reactive force from the piston to the other side of the rotor.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 11-11-2019, 10:35 AM   #23
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Most all automotive disk brake systems use a 2 psi RPV somewhere in the system, it's usually built into the master cylinder.
If the actuators (master cylinders) used on RV trailers don't have a built in RPV, then the addition of an inline RPV will help the response time of the trailer brakes and is not likely to negatively affect brake life in a meaningful measure.
Brake Wire... improvement Ray Eklund Brakes & Brake Controllers 6 08-21-2019 10:47 AM
For OEM brake controller with Airstream's disc brake setup cmkirkland Brakes & Brake Controllers 16 01-28-2016 09:17 PM
Poor brake performance. Even after new brakes. timmaah Brakes & Brake Controllers 64 08-25-2013 10:08 PM
Bambi Improvement Request DreamStream Our Community 2 01-24-2004 09:46 PM
Frustration_forum improvement ? femuse Our Community 24 03-27-2003 04:58 PM
