Old 07-21-2009, 04:40 PM   #1
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Disc Brake Pad Disintegrates On '06
As some of you know I had a brake line fail (spring a leak) on our trip down to Morris Meadows last year (http://www.airforums.com/forums/f439...end-45278.html). Well a year and two months later the excitement was on the way home from the same campground. On the trip back home the road side front outside disk brake pad on the trailer disintegrated. The trailer braked just fine on the way home and I did not notice it until I was leveling the trailer and chalking the wheels in the driveway. I noticed that the road side front brake rotor looked “funny,” it was all scored up, not shinny like the other three. So I jacked the trailer up and pulled the wheel to find the outside brake pad had disintegrated and the baking plate for the brake pad had been rubbing on the rotor. So basically the brake pads, rotor and the brake calipers are ruined!!! I called Airstream to see if there was anything they could do even though the trailer is out of warranty. They recommended that I try Dexter. So I am going to call Dexter tomorrow to try and get them to cover it under warranty. But if they don’t it will cost me all but $900.00 in parts to fix it. Luckily I can fix it myself and will not have to pay the exorbitant labor rate at an RV dealer.
Here are some pictures of the mess. The inside brake pad shows normal wear and still has 5/16" of pad material.
You can see the scoring on the rotor from the brake pad backing plate rubbing on the rotor.
The rubber boots on the caliper are shot.
What was left of the brake pad found in one of the caliper cups.
ID:	84272   Click image for larger version
ID:	84274   Click image for larger version
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 07-21-2009, 06:28 PM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Read your previous post last year, here we go again. Glad no serious consequences
The last time I cruised the Colonial website I noticed some of the 09's & 10 are back to drums. Wonder if there is something they ain't tell'n us. When AS first started using disc's I thought of the upgrade, maybe holding off for awhile was the right thing, wait and see.
Good luck and "STREAM SAFE"...sic.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 07-21-2009, 06:32 PM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Also glad no serious damage.
They may be back to drums since actibrake is no longer.
Michelle TAC MT-0
Sarah, Snowball
Old 07-21-2009, 08:12 PM   #4
DEITZ645's Avatar
I read a post to a thread here that they were switching to the hydraulic brake pump actuator from Dexter.
I guess one of these two...
Dexter Axle - Trailer Axles and Running Gear Components - K71-650-00 E/H1000 (Drum Brakes)
Dexter Axle - Trailer Axles and Running Gear Components - K71-651-00 E/H1600 (Disc Brakes)
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-21-2009, 11:18 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, without everything right in front of me to see with my own eyes, I would say that you have a caliper slide problem; Symtems, One pad shot other side/pad, OK. Where ever the pads and or calipers slide they need to be lubed with Brake lube or Anti-seize. You can reseal the caliper [new boots] and replace the pads and rotor. I would pull all of the brakes and lube all points of movement with Anti-seize. More than likely not covered by warranty, but it wouldn't hurt to try.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-22-2009, 03:43 AM   #6
WK57ABF's Avatar
2007 25' Classic
kendal , cumbria, UK
ROBERTSUNRUS - Our 07 Classic has fixed calipers. Not sure whether the 06 had
floating calipers.
John in the UK
WK57ABF is offline   Reply With Quote
Old 07-22-2009, 05:02 AM   #7
DEITZ645's Avatar
Our '06 has fixed calipers. I will see if I can rebuild the calipers. Thanks for the information.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-22-2009, 07:24 AM   #8
2009 30' Classic
Salem , Alabama
Bob is correct in his diagnosis: I had the same pad problem with an LTD Ford,which had set on the docks in Brm GER for a month, while waiting shipment. The inner pad slide slot had rusted from salt water exposure. After pick-up in SC ,and the drive to Tn; the inside pad/caliper/rotor were destroyed.woppa4
woppa 4 is offline   Reply With Quote
Old 07-22-2009, 11:56 AM   #9
DEITZ645's Avatar
Thumbs up Bit Of Good News From Dexter
I just got off the phone with Connie at Dexter Axles. They were very nice and cooperative. Since they only offer a 2-year warranty the agreed to sell me the parts that I need at 1/2 of retail. I also found out that they have a caliper rebuild kit so I wouldn’t have to purchase an entire caliper assembly (the most expensive part of the lot).
So the prices came to;
Caliper rebuild kit - $15.60
New rotor - $77.59
8 brake pads to do both axles $179.34
Total - $272.53 - Which is quite a bit shy of my original estimate of $889.11 so I am happy.
Once I get the parts I will post notes and picture of the rebuild and assembly.
Hopefully this will be the last of my brake issues on this trailer.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-22-2009, 12:52 PM   #10
2009 30' Classic
Salem , Alabama
? is the rotor so damaged that an auto/brake shop couldn't turn or resurface the rotor. woppa4
Old 07-22-2009, 03:28 PM   #11
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Bob's got it right! It appears that you have a floating caliper that automatically centers itself on the rotor. A fixed caliper has pistons on BOTH sides of the rotor, a floating caliper has pistons only one ONE side. When you burn through one pad prematurely, that means that the caliper hangs up and makes one pad do all the work. For your kit, you need only replace the outer dust boots and save yourself some work. Check your other calipers for an incipient problem too.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-22-2009, 04:49 PM   #12
DEITZ645's Avatar
Wopa 4,
It's pretty messed up. I will take it to a shop to see if it can be turned, but I would just as soon have a new one.
Excella CM,
From your description I definitely have fixed caliper brakes, because there are a total of four pistons; two on each side of the rotor.
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-22-2009, 05:01 PM   #13
DEITZ645's Avatar
Necessity Is The Mother Of Invention
Since I am going to be able to rebuild my calipers I was chomping at the bit to get the pistons out of the bores and clean everything. So when I got home from work I fired up the air compressor and tried to blow the pistons out into a towel. Well it worked great for one of the two pistons on each side of the caliper which left one remaining in each side...how to get that second one out???? After pondering on it for the better half of an hour it finally struck me...The bores looked about the same size as the rubber plugs I use to plug up the return jets in our pool when I winterize it. I dug one out and sure enough it fit like a glove. I tightened the wing nut which causes the plug to expand and it sealed perfect. I applied some air pressure and POP the remaining pistons was expelled from their bores. Now all I have to do is wait for the replacement parts to arrive some time early next week.
Here are some pictures of the solution to the problem...
ID:	84332   Click image for larger version
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 07-22-2009, 07:16 PM   #14
Excella CM's Avatar
Venice , California
You still need to identify the cause of the lopsided braking effort. This could either be a problem with pressure distribution (unlikely) or the pad hanging-up. Or something else.
Disc brake upgrade Tin Diesel Brakes & Brake Controllers 15 11-19-2008 07:50 AM
77 disc brake problems tschat Brakes & Brake Controllers 10 06-22-2007 12:35 PM
Disc Brake Controller rrpranch Brakes & Brake Controllers 20 05-09-2007 11:25 PM
disc brake question wayne.yl Brakes & Brake Controllers 11 06-22-2006 07:16 AM
Disc Brake owners Inland RV Center, In Brakes & Brake Controllers 40 03-16-2005 05:29 PM
