Old 03-11-2005, 05:39 PM   #1
Disc Brake owners
Techonsha's catalog #95000, on page A-2, states in bold print, the following information about their Prodigy Brake controller.
NOTE: Not designed for use with electric/hydraulic trailer brake systems.
Old 03-11-2005, 06:30 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
andy,
so what is the best controller for those who have disk brakes?
good old fashioned kelsey hayes with the brake line tap?
john
you call them ferrets, i call them weasels.
Old 03-11-2005, 06:56 PM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Linear?
I would think a linear pressure controller woul dbe great for disc brakes.
either a Jordan, with the cable on the brake pedal, or one of the ones with a brake fluid pressure sensor.
I imagine that the Prodigy is not suitable because of it's boost modes.
I imagine the boost modes locking up disc brakes momentarily every time you hit the brakes.
But then,as usual, I could be totally wrong.
Uwe
www.area63productions.com
Old 03-11-2005, 06:59 PM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Andy recommended the Hayes-Lemmerz Energize III for my '77 Excella 500 HydraVac disc brake system. I purchased the brake controller from him and it has worked just fine. I'm not sure what he recommends for the newer disc brake systems.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-11-2005, 07:39 PM   #5
Images: 59
Masterbrake makes a brake controller that tees into the brake line. It works with their brand of hydraulic pump, but I don't know about the Actibrake system.
http://www.masterbrake.com/brakesmart.html
Old 03-12-2005, 11:20 AM   #6
Installing a "T" in hydraulic brake lines has been illegal for many years. If I recall, it's been outlawed for over 30 years.
Any high quality "inertia" type electronic brake controller will work with the Actibrake, as per actibrake.
Old 03-12-2005, 11:56 AM   #7
jordandvm's Avatar
2017 28' International
Western , Oregon
Images: 58
Which AS trailers have disc brakes installed? We purchased a 2005 28' CCD and it states on the mfg's standard items sheet it has 12" electric drum brakes, which I assume it to mean that it does not have disc brakes. We have a Tekonsha Prodigy brake controller on our TV. I'm not familiar with all the brake terminology. Please clarify!
Jim & Cheryl
2017 28' Signature CCD
2017 GMC Denali HD Crew Cab 4x4
Blue Ox Sway Pro Hitch
WBCCI #3538
jordandvm is offline   Reply With Quote
Old 03-12-2005, 12:15 PM   #8
Jordandvm.
Your trailer has electric brakes.
The Prodogy controller will work OK for your trailer.
Airstream says they are installing disc brakes as standard equipment, as of February 1st, this year, on the larger trailers.
Airstream had as an option, disc brakes from the late 70's to the early 80's.
Old 03-12-2005, 12:38 PM   #9
Images: 59
You don't understand the concept. The 'tee' in the brake line is to install a small transducer, which signals the controller to apply a proportional signal to the brakes.
I think this is a more direct, faster response than depending on a pendulum.
This is similar to the new Ford 'Tow Command' system, built by Tekonsha.
Old 03-12-2005, 01:00 PM   #10
davidz71's Avatar
1986 25' Sovereign
I'm sure Andy fully understands the concept. He was right in the middle of the disc brake movement of the 70's.
The old brake controllers monitored the tow vehicle's brake pressure and supplied a proportional electrical current to the synchronizing valve on the tongue of the 70's trailers. Adapter tees, available for numerous vehicles, were installed in the port servicing the rear wheels at the hydraulic unit under the hood of the vehicle. I'd say that improper installation or improper maintenance may have caused vehicle manufacturers or DOT to take a dim view of this concept but it does work if properly installed.
Craig
AIR #0078
3.73 rear end
Old 03-12-2005, 01:12 PM   #11
Images: 59
Craig,
I don't think you looked at the Brakesmart controller either. It's not the same as the old Kelsey Hayes controllers (yeah, I had one).
This is 'new technology'. I don't think it's illegal.
Old 03-12-2005, 01:16 PM   #12
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
my owners manual for my silverado states you may tap into the brake system if the following requirements are met:
the trailer parts can withstand 3000 psi
the trailers brake system will use less than 0.02 cubic inch of fluid from your trucks brake system.
in otherwords, don't!
john
Old 03-12-2005, 01:32 PM   #13
davidz71's Avatar
1986 25' Sovereign
I would say that the transducer would be a better idea than the old hydraulic line through the firewall and connected to the brake controller inside the vehicle. The question is, how much brake fluid is displaced from the system when acting on the transducer. If less than the amount johnhd mentions then you are probably OK. The potential for a "unqualified" mechanic installing the transducer in the system where it later leaks is the variable here. If I had the system, and I have been wondering just how good it is, I would make sure someone who knew what they were doing (and would back up their work) installed it. I have heard good things about MasterBrake and BrakeSmart but have not personally seen one or driven a TV with one installed. Heck, it might be the best thing going if installed correctly. You gotta know that the vehicle manufacturer has no control over the new addition and would not even look at a claim involving brakes should something happen.
Craig
AIR #0078
3.73 rear end
Old 03-12-2005, 01:39 PM   #14
Images: 59
Craig,
I don't know what the displacement is, but I use similar transducers im my practice and the displacement can be less than .02 ci.
Obviously, an unqualified mechanic can screw up the installation of just about anything.
disc brakes overlander Brakes & Brake Controllers 10 01-25-2003 11:29 PM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
