Old 01-31-2010, 07:09 PM   #1
wildwoodrver's Avatar
2012 30' International
Pleasant Hill , The Golden State
Disc brake lag
Just upgraded to Kodiak discs, driven with a Titan BrakeRite EHB, and controlled with a new Tekonsha P3.
There is a 1.5 second delay before the trailer brakes apply, as measured with the manual control.
We've bled the brakes 4 times and checked voltage on both the constant and application wires at the actuation device. (With Titan support on the phone....all normal).
Getting worried about losing precious time in a panic. Love the way they work otherwise.
Any ideas?.....thanks.
2012 International Serenity, 30
Reese Trunnion Weight Dist. Hitch
2005 GMC Yukon XL, Tekonsha P3
Reese Tow Beast hitch
Quadrasteer - Autoride
wildwoodrver is offline   Reply With Quote
Old 01-31-2010, 07:40 PM   #2
Sounds like there is a problem with the actuator.
That time lag, is a safety hazard.
Old 01-31-2010, 11:06 PM   #3
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
hmmm... are you sure you have the right EHB? There's a 1000 psi one for drum brakes, and a 1500 for disks.
The correct one has part # 4813100
Failing that, it seems like you might have a defective actuator.
Marc
Old 02-01-2010, 10:22 AM   #4
I double checked....it is the right part number.
It keeps telling me the actuation system is defective. That is sort of last resort, and if I have to change it I might opt for a different brand....you sort of loose faith when a product doesn't work as advertised.
Getting used to the lag, but of course I get a Hensley bump if I hit the foot brake hard at speed.
Thanks.
Old 02-01-2010, 11:35 AM   #5
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
I agree with Andy, you can't live with that big of a delay in trailer braking action. In the right conditions (panic stop), the lag could give the trailer a chance to push you off-center and out of control.
Since you've already done tech support (and thereby given Titan a fair chance to resolve the problem), my next step would be to investigate returning the unit and replacing with another make of actuator.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 02-06-2010, 05:33 AM   #6
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Did you get this resolved?
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 02-06-2010, 07:26 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thanks.
The bump is not Hensley, ProPride or normal, proper set-up is needed.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-20-2010, 07:27 AM   #8
Final Chapter in the saga of the brake lag.
I relocated and isolated the ground wire from the Titan pump from a common ground bus in the trailer, directly to the ground wire coming in from the 7-way plug. Problem solved. Lag gone. Well, nearly gone. It is 1/2 second or less on manual override and not noticeable with foot brake. They stop as advertised. Seems the ground must find it's way back to the battery for proper operation.
As for the "bump" I have that under control too. Bob is right; you have to really fine tune the alignment to eliminate the bump in hard braking. If the trailer is pulling, even slightly, to one side, you will feel it take out the slack with hard braking. It just takes some patience and making small adjustments.
Thanks for your input. Now we can focus on enjoying the journey.
Old 03-24-2010, 05:42 PM   #9
JFScheck's Avatar
Rockville , Maryland
Images: 33
Gotta give it a micro seconds to pressurize I would imagine?
I was just reading in my owners manual about my Disc Brakes - wanted to ask you if your new system has a "Brake & Hold" feature were it will hold the brakes without running the pump (I think up to 15 seconds) re-pressurize via the pump - then hold for another 15 seconds (or was it 45 seconds, damn)...
Curious to how this feels when stationary - note it only occurs when the foot is on the brake...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 03-24-2010, 05:56 PM   #10
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
I should have thought of the possibility of a ground wire problem. We've had ground problems a couple of times. With the Actibrake, even a marginally bad ground will cause the unit to simply stop working entirely. More than once I've had to pull over and clean the main ground wire to the trailer frame before proceeding. Interesting that the Titan BrakeRite showed a lag as the symptom instead.
Old 03-24-2010, 06:01 PM   #11
_
Originally Posted by JFScheck View Post
...wanted to ask you if your new system has a "Brake & Hold" feature were it will hold the brakes without running the pump (I think up to 15 seconds) re-pressurize via the pump - then hold for another 15 seconds (or was it 45 seconds, damn)...
there are several old thread on this issue but most are for PRE '08 gear.
my understanding is the HOLD feature largely depends on WHICH actuator/controller circuit board is used.
which one is IN/ON your trailer?
actibrake is outta biz so your unit may be carlisle or dexter or ???
the majority used by a/s were actibrake but this changed in the last 2 years.
it also depends on the brake CONTROLLER in the tv...
for example the itbc in my ford only sends power (voltage) when the truck is MOVING...
so after stopping, for example on a HILL at a STOP LIGHT, or at a RR crossing...
the brake controller STOPS sending a signal and the 2 vehicles are held stationary by the truck brakes...
then as the truck start moving voltage is PROPORTIONAL up to 5 (or 10) mph where it is at FULL power.
at least that is what i think is happenin'
cheers
2air'
Old 03-30-2010, 08:17 PM   #12
JFScheck's Avatar
Images: 33
Searching Threads now - thanks...
**I Love U.S.A.**
Disc Brake Maintenance Steve & Mary Brakes & Brake Controllers 7 12-14-2009 11:06 AM
Disc brake upgrade Tin Diesel Brakes & Brake Controllers 15 11-19-2008 07:50 AM
disc brake question wayne.yl Brakes & Brake Controllers 11 06-22-2006 07:16 AM
Disc Brake owners Inland RV Center, In Brakes & Brake Controllers 40 03-16-2005 05:29 PM
Disc Brake kits Inland RV Center, In Commercial Listings 0 11-01-2004 05:44 PM
