Old 12-03-2014, 12:00 PM   #99
dznf0g's Avatar
Oswego , Illinois
So air is now heavier that fluid?
-Rich-
Old 12-03-2014, 01:17 PM   #100
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
What a crazy design not to put a bleed valve on the one caliper. Are all their dual caliper discs designed this way or only us Classic owners lucky?
Old 12-03-2014, 01:24 PM   #101
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Originally Posted by ROBERT CROSS View Post
Can I have a KISS.....please.
Originally Posted by Inland RV Center, In View Post
As per your request.
Be Careful, he did not say where he wanted to be kissed.
Ken
Old 12-03-2014, 01:41 PM   #102
SteveH's Avatar
Common Sense , Texas
I guess Dexter air is heavier than fluid..........
Regards,
Steve
Old 12-03-2014, 01:42 PM   #103
SteveH's Avatar
I have ordered the 2lb residual valve. We'll see.
Regards,
Steve
Old 12-03-2014, 02:31 PM   #104
dznf0g's Avatar
Oswego , Illinois
Let us know.....I'm struggling with 2psi X the surface area of the four pistons = how many pounds of apply force? What's the drag, heat buildup and wear factor. There are no balancing retraction springs on those pads/calipers.
-Rich-
Old 12-03-2014, 02:37 PM   #105
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
If at all possible bleed the actuator WELL before tightening the output line.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 12-03-2014, 02:40 PM   #106
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
A two PSI RPV should not cause any appreciable drag unless it is behind another 2 PSI valve already in place in the actuator, I seriously doubt there is one already in the actuator.
Old 12-03-2014, 02:45 PM   #107
dznf0g's Avatar
Oswego , Illinois
I'm not sure how to measure "appreciable drag" in terms of wear and temp, but if you think about it:
If the gravity force of a column of fluid in a street rod, whose MC is lower than the caliper, has enough "suction" to retract the piston and make a low pedal, then 2 psi will surely keep the pads in constant contact with the rotor, overcoming the retraction and gap between rotor and pad caused by normal hub/bearing/rotor runout. I'm not saying it's a bad idea....I'm just not sure it's worth the tradeoff for me.
-Rich-
Old 12-03-2014, 02:52 PM   #108
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Would not a Mityvac help?
Old 12-03-2014, 02:56 PM   #109
dznf0g's Avatar
Oswego , Illinois
No, Bob. No matter how hard the mighty vac pulls, it'll never pull the air from the top to the bottom of the inner caliper half, through the connecting line, in order to let it rise to the bleeder.
-Rich-
Old 12-03-2014, 03:04 PM   #110
SteveH's Avatar
Rich,
All I know is you could not feel any drag on the wheels on the cars with them lifted off the ground and rolling them by hand. I did this many times aligning front ends. Actually, a semi-tight adjusted drum brake had more drag, as I remember.
Regards,
Steve
Old 12-03-2014, 03:08 PM   #111
dznf0g's Avatar
Oswego , Illinois
Rich,
OK, you're the guinea pig then?
-Rich-
Old 12-03-2014, 03:09 PM   #112
SteveH's Avatar
J.M.
What I did the first time when I replaced the Actibrake with the Dexter was lifted the tongue of the trailer as high as I could get it, changed the unit, then bled the unit to the first junction in the brake line. Think it was at the "T", and the delay was no longer, or shorter than with the Actibrake.
I'll need to get a short section of brake line to install the valve.
Regards,
Steve
Disc brake parts, pads and calipers Excella CM Brakes & Brake Controllers 31 04-16-2011 08:37 PM
Disc Brake owners Inland RV Center, In Brakes & Brake Controllers 40 03-16-2005 05:29 PM
Disc brake Retro fit kits Inland RV Center, In Commercial Listings 57 01-29-2005 10:17 AM
Disc Brake kits Inland RV Center, In Commercial Listings 0 11-01-2004 05:44 PM
Tandem disc brake kit Inland RV Center, In Commercial Listings 2 10-30-2004 11:25 PM
