Old 12-02-2014, 10:18 AM   #71
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
"To address the other post about calipers becoming stuck.....not multi-piston calipers where pistons are on both sides of the rotor. On those, the caliper is fixed and all motion is in the pistons which compress each pad independently. Single piston calipers slide on the knuckle, or hub flanges. If those sit for an extended period (like years), they can stick and cause h"
I am looking hard at the Dexter axles. The disc brake option they show (3500 lb axle) certainly looks like a single piston caliper that slides on bolts to me. Is that not what Airstream uses also? Is that a reason to avoid the Dexter? Or maybe to buy it since it should bleed fine?
Old 12-02-2014, 10:22 AM   #72
SteveH's Avatar
Common Sense , Texas
Just my opinion, but I would prefer the single piston caliper because they are easy to bleed.
Regards,
Steve
Old 12-02-2014, 10:40 AM   #73
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Disc brake discussion
The Dexter calipers on my Dexter axles (as mentioned above) are one piston designs that have proven bulletproof over decades.
Not a single failure to report here ever, nothing.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 12-02-2014, 12:17 PM   #74
dznf0g's Avatar
Oswego , Illinois
The ones used on Classics (and optional on others, I think) in the mid 2000s are 4 piston calipers. Not sure what Dexter uses now. The Classics went back to Electric brakes in 2011 or 2012.
I'd probably prefer a single piston E/H as well. If the 4 piston were executed properly, I'd prefer them, but the single piston would certainly be easier to maintain.
-Rich-
Old 12-02-2014, 12:26 PM   #75
dznf0g's Avatar
Oswego , Illinois
It looks like here:
http://dexteraxle.com/i/u/6149609/f/...rake_Flyer.pdf
That 3500# are single piston and >3500# are 4 piston.
-Rich-
Old 12-02-2014, 12:31 PM   #76
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
The pictures in that document show the bleed valves on the top with the supply lines on the bottom on the inner and outer calipers. Is that not what my 2008 Classic calipers look like? Should be easy to bleed all the air out on those calipers. My Classic is 8000 GVWR.
Kelvin
Old 12-02-2014, 12:38 PM   #77
dznf0g's Avatar
Oswego , Illinois
Kelvin
No, they have the supply fitting on the top of the inner housing, a "transfer line" joining the two halves, at the bottom of the halves and the single bleeder on the top of the outer. Pics don't show the bottom nor the inner half in deatil.
-Rich-
Old 12-02-2014, 12:42 PM   #78
dznf0g's Avatar
Oswego , Illinois
http://www.dexteraxle.com/i/u/614960...t_6K_7K_8K.pdf
Note, the axle is uoside down on the floor in these pics.
-Rich-
Old 12-02-2014, 12:43 PM   #79
dznf0g's Avatar
Oswego , Illinois
Dexter Axle - Trailer Axles and Running Gear Components - 8K Disc Brake
The bottom pic shows all four fittings pretty clearly.
-Rich-
Old 12-02-2014, 05:56 PM   #80
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Interesting.. Wonder if actuators can handle 6 brakes? ����
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-02-2014, 06:14 PM   #81
SteveH's Avatar
Mine does, well sort of.
Regards,
Steve
Old 12-02-2014, 06:15 PM   #82
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Both my tri axles have 6 calipers, flawless for combined hundred if thousands of miles!
Old 12-02-2014, 06:33 PM   #83
SteveH's Avatar
Are your calipers the four piston, or the single piston? And what actuators do you have?
Regards,
Steve
Old 12-02-2014, 07:06 PM   #84
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Playing from memory, I am about sure that there is a Dexter model that will handle six brakes. I am 99% on this.
Disc brake parts, pads and calipers Excella CM Brakes & Brake Controllers 31 04-16-2011 08:37 PM
Disc Brake owners Inland RV Center, In Brakes & Brake Controllers 40 03-16-2005 05:29 PM
Disc brake Retro fit kits Inland RV Center, In Commercial Listings 57 01-29-2005 10:17 AM
Disc Brake kits Inland RV Center, In Commercial Listings 0 11-01-2004 05:44 PM
Tandem disc brake kit Inland RV Center, In Commercial Listings 2 10-30-2004 11:25 PM
