02-02-2018, 10:02 AM
2002 30' Classic S/O
Fleming Island
Disc Brake Conversion SUCCESS!
Wednesday I had my axles replaced and, in the process, converted to disc brakes. Wow! What a difference. I haven't driven it much yet, but I did take some data points before and after by stopping the truck/trailer combination with just the trailer brakes. All tests run with the integrated brake controller in my 2013 Ram 2500 set at Heavy Electric and Gain of 10. I forgot to change it to hydraulic, Duh.
2002 Classic 30 Slideout, GVWR 9100#
OEM 12x2 drum brakes, properly adjusted
25mph to 0mph - 12 seconds
45 mph to 0 mph - 30 seconds
Kodiak integral rotor disc brakes with Carlisle Hydrastar 1600 psi actuator
25mph to 0 mph - 6 seconds
45mph to 0mph - 11 seconds
These test were run right after installation, the brakes probably had not bedded in well yet.
When I tried the 25 mph test the next day, the brakes actually locked. I had been unable to lock them with the drums. I am now running with the gain set at 8.5 to eliminate lockups. I switched to Heavy Hydraulic and discovered that the brakes come on earlier and harder at first. That should improve the lag I felt when driving home from the shop with them set on Heavy Electric by accident.
So far I am extremely pleased with the conversion. I'll report after our rally trip this weekend and next.
Al
02-02-2018, 10:20 AM
Oswego
Good for you. I've anecdotally known what you state ever since I sold my SOB with drums
and bought my 07 Classic with discs. First trailer I've ever towed with which behaves close...but only close, to automotive feel and predictability. They have their quirks, due to the electric interface at the actuator, but they are far superior.
-Rich-
02-02-2018, 10:24 AM
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
We had disc brakes installed on our 29' Classic about 12 years ago. They are wonderful! Anyone who says drum trailer brakes (when properly adjusted) work as well as discs hasn't towed/stopped with disc brakes. Ours have been working well for nearly 100,000 miles with only one set of new pads installed and the discs are original.
Hope you get many miles from your setup and the brakes give you more confidence when traveling.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
02-02-2018, 10:25 AM
2007 30' Classic S/O
Somewhere
, South Carolina
Al,
Maybe we need those bumper stickers I frequently see on Canadian trailers, warning that the trailer is disc brake equipped and stops on a dime.
Now just enjoy and get to know your new stopping system.
Congrats.
Gary
02-02-2018, 02:12 PM
Fleming Island
I was totally satisfied with the drum brakes on my 25' Safari with a GVWR of 6300#. The truck/trailer combo stopped as well as the truck alone. I had to set my P3 controller to about 7 to avoid locking the brakes.
When I got my Classic 30 Slideout I was unable to get the brakes to lock at full gain on the integral controller. I bought a used P3 to see if that made any difference. It pointed out that my umbilical cable had high resistance; I was only getting about 8 amps to the brakes while the breakaway switch had over 11. With the new umbilical I got up to about 10.5, and braking improved slightly, but still no lockup. The kicker is that the 9100# Classic had exactly the same brakes as did the Safari - 12x2 drums. Seems odd that a 50% increase in GVWR didn't result in bigger brakes in the design of the Classic.
Al
02-02-2018, 02:21 PM
2007 27' International CCD FB
San Diego
Great information. Seems to be an important modification, especially for longer/heavier trailers.
This would also be useful for those that have gone up on tire/wheel size. Either from 15" to 16" wheels, or increasing tire size from 225/75/15 to 235/75/15, or anything that increases tire diameter really, where brake torque is lost.
02-02-2018, 02:38 PM
Fleming Island
Good point about the wheel size. I did replace the 15" tires and wheels on the trailer when I bought it with the ones I had on my 25. So the comparison between the two trailers is still valid, but a stock Classic 30 Slideout might perform differently.
That said, I seem to have gotten 2-3 X more braking with the discs.
Al
Al
02-02-2018, 08:11 PM
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Very good report. I like the experiments you did and the data you collected. Wow, what a difference. And I'm sure the disc brakes will perform very well on long downhill desents.
I'm installing new axles on my 75 Overlander. Dexter supplies 10x2 1/4 drums on all axles rated less than 3500 pounds. It is a industry standard so I'm told. The old axles had 12v2 drums that are typical on 5000 pound rated axles. I'm having some heartburn about losing braking force, especially here in Colorado and especially towing the 5500 pound trailer with a SUV.
Maybe I can start a disc brake project after the fact on my new axles if I am unhappy with the 10" drums. TouringDan put disc brakes on his Trade Wind with good results.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
02-03-2018, 09:23 AM
2004 30' Classic Slideout
2021 33FB Classic
Colleyville
, TX
We had disc brakes added to our 2004 Classic Slide Out several years ago and they are just awesome! Like adding the Hensley, it took me a while to decide to spend the money but what a difference adding both. The peace of mind was worth the expense.
In dog years, I'm dead!
02-03-2018, 09:26 AM
Still Dreaming
1971 29' Ambassador
Sulphur Springs
I'm trying to get a feel for this..... do you have any idea what that works out to in stopping DISTANCE? To my uneducated mind 12 seconds sounds like forever!
02-03-2018, 09:33 AM
2021 33FB Classic
Colleyville
, TX
Too many variables my friend. Our rig with the slide and fully loaded weighs in at four plus tons and with disc brakes added I can tell you that at times I can feel the trailer breaking the truck. The disc brakes at least help substantially. At one point we were considering trading for a newer model Airstream when I was shocked to learn the disc brakes were not an option as I thought they once were. We decided to keep our well maintained and periodically upgraded 2004. I'd be hard pressed to purchase any heavy trailer without them.
02-03-2018, 09:50 AM
belen
, New Mexico
Discs
My orig 79 had em and I spend a bucket of cash to keep them operating.
It Was worth it for the smooth braking
02-03-2018, 09:54 AM
2009 30' Classic
Crestview
Hi Al & Missy.
Our 2009 30 Classic has dexter disc brakes and actuator. Way better stopping than our 2010 27’ International that was 1,000+ pounds lighter.
I would not want a trailer this heavy without discs. No new one for us either.
Paul &. Holly
San Diego
Note that his tests were done with actuating only the trailer brakes, which removes the variable of brake gain with the tow vehicle.
02-03-2018, 10:48 AM
2016 25' Flying Cloud
2003 22' International CCD
2004 28' Safari
Sahuarita
Cost
What is the approximate cost to have the conversion done?
02-03-2018, 12:19 PM
White Bear Lake
I don't understand why everyone wants to be able to lock up their trailer brakes. The contact patch between the tire and the road, (where the rubber meets the road), is not a brake.
Have you ever had the brakes lock up on your tow vehicle on a slippery surface. You had no direction control. The vehicle went where it wanted. Your first response should be to release the brakes to regain directional control. A trailer will do the same taking any track physics dictates. If the anti-lock brake system on the tow vehicle is working as it should the locked up trailer could try to pass the tow vehicle. And you thought that deer in the headlights was a big hazard.
More effective brakes are useless if you consistently lock them up. The function of brakes is to convert energy to heat. Disk brakes do this much better than drum brakes. Keep the energy conversion in the brakes, not in the tires.
The reason for anti-lock brake systems is to minimize the duration of brake lock up. The wheel is kept turning and the brakes are absorbing the energy even when the driver dynamites the brakes.
Don't allow the brakes to lock up.
02-03-2018, 02:28 PM
Salem
, Oregon
Hi, you are right and that is why you are supposed to set the brake controller properly.
Warm up your brakes by driving a few blocks first.
Drive to 25 MPH and manually apply your trailer brakes.
Increase gain until your tires skid then back off just enough so they don't lock up.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
02-03-2018, 02:42 PM
Somewhere
, South Carolina
I don't think Al or myself wants them to lock up all the time. But if your best efforts all tuned up and the drums CANNOT lock up and then discs can lock up w/o much fuss then you just dial down the controller to get max braking and no skidding. That's when the brakes are doing the job. And it shows how much more effective discs are.
I'm a disc brake equipped trailer guy.
Gary
02-03-2018, 09:27 PM
2007 22' International CCD
Corona
Disc brakes are on our important improvement list...
02-04-2018, 04:14 AM
Mantua
, Ohio
One of the best things for the money, disc brakes. Maybe the new trailers need fewer tech gizmks abd more safety things like disc brakes!
