Old 01-21-2015, 06:42 PM   #113
George
2007 25' Classic
Calgary , Alberta
Originally Posted by dznf0g View Post
... got the new electrical architecture.
So, does it mean that the "new architecture" work with the Airstream EOH brakes?
George
2007 Classic 25'/ 2013 Cayenne GTS/ 2015 GMC 2500HD Denali
gwmc is offline   Reply With Quote
Old 01-21-2015, 06:45 PM   #114
dznf0g's Avatar
Oswego , Illinois
Yes, as far as we know, it works with all current EOH actuators......equally well, I don't know. If all the brands of actuators had the same electronics, I could be more accurate, but the new architecture does recognize a trailer being present without the resistance of magnet coils.
-Rich-
Old 01-21-2015, 06:59 PM   #115
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Consult with TUSON. They unfortunately disqualify my manual transmission Dodge diesel.
I would want my rig to have an integrated brake system to the greatest extent possible. All TUSON all the time, at present.
Old 01-21-2015, 07:13 PM   #116
dznf0g's Avatar
Oswego , Illinois
I like my Direclink A LOT. But I haven't had a new gen truck to try the new controller. I pick up one next Monday. I'm going to give it a run and compare to Tuson. (a tough standard to meet, IMO)
-Rich-
Old 01-22-2015, 08:05 AM   #117
Brookfield , Wisconsin
Some individuals above asked if there is anything else they should consider in brake controllers? One thing worth serious consideration would be an "anti sway controller" used with your existing electric brakes. The Tuson unit accepts power from your trailer battery/vehicle charge system and the existing blue wire and then individually controls the left and right brakes during trailer sway events. A sensor internal to the unit detects the direction and sway angle and then applies the brakes at different levels relative to the amount of trailer sway. Since individual brake control is needed to "do an effective job of sway control" you need to separate left and right brakes and connect them individually to the controller. Anyone whom has experienced a sway event likely does not want to experience it again. The unit also performs the same functionality while blue wire braking is applied. Just thought it is something worth considering if you are focused on electric trailer braking.
C5Don is offline   Reply With Quote
Old 01-22-2015, 12:06 PM   #118
George
2007 25' Classic
Calgary , Alberta
Originally Posted by C5Don View Post
...and then individually controls the left and right brakes during trailer sway events ... you need to separate left and right brakes and connect them individually to the controller.
I assume this is only feasible with standard electric drum brakes. Electric over Hydraulic systems don't have separate hydraulic circuits to left and right wheels.
George
Old 01-22-2015, 02:23 PM   #119
dznf0g's Avatar
Oswego , Illinois
I think you would have to use the Tuson actuator in order to use the Tuson E/H sway controller. There are 2 hydraulic ports on both their actuator and ABS module.
-Rich-
Old 01-23-2015, 08:40 AM   #120
Relative to electo-hydraulic, no it is not designed to operate on that system. It will work with most typical brake controllers and electric brakes and does not require a Tuson brake controller. On some brake controllers at the low end of the market may require the installation of a 47 ohm load resistor, 16 watt or more, on the blue wire to ground to work properly. Adding this resistor then disables a sway controller feature where it "disconnects blue wire to cause the brake controller to indicate not connected" when the sway controller detects various faults, like a shorted brake magnet. However, this status is also indicated on an LED that is generally mounted in a rear view mirror visible location on trailer" thus you can still see faults, just won't get "beeped at". To some users that may even be considered a feature. You can get this type of resistor from places like digikey, mouser and such. With controllers like Prodigy and such you will be fine as it uses blue wire interface techniques similar to the Tuson brake controller and thus does not require the resistor. With brake controllers you generally get what you pay for. In the trailer market some of the interfaces are like the "wild west" a product designer can do almost anything they want and some of these controller are thus designed to "only work" with electric brake magnets and thus do some things the "easy way" and thus are not compatible with various "electronic interfaces". Definitely an area where the RV industry should define an "interface standard" to eliminate customer grief in this area. You can contact Tuson if you have any specific controller compatibility questions. Hope this helps.
Old 01-23-2015, 09:22 AM   #121
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
C5Don, thanks for this and your other recent posts.
Old 01-02-2016, 07:57 PM   #122
2015 23' Flying Cloud
Livermore , California
Does anyone know if DirecLink works with a 2007 Lexus GX470?
cactusjk is offline   Reply With Quote
Old 01-03-2016, 08:37 AM   #123
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The Tuson gets it's information from the on board diagnostic port in US model trucks and perhaps cars. Not sure if a Lexus has that standard port used here or has a proprietary plug-in for their mechanics.
We purchased the DirecLink NE for future ABS compatibility on the trailer when we convert from standard disc brakes to ABS disc brakes using the Tuson brake pump system.
Old 01-03-2016, 08:58 AM   #124
Their site lists Toyotas 2008 and up but also sells a cable for 2007 Lexus GX 470s. Lexus uses the standard ODB codes.
Brake controller incompatibility? Flying Gypsies Brakes & Brake Controllers 7 10-31-2011 12:41 PM
Brake controller adjustment problem Zettervall Brakes & Brake Controllers 9 08-30-2011 07:58 PM
How can I test/verify my Brake Controller? Gastrolith Brakes & Brake Controllers 6 06-28-2011 01:34 PM
RF causing brake controller malfunction nm1oqrz Phone, CB & Ham Radio 6 04-12-2011 06:03 PM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
