Old 05-03-2015, 02:05 PM   #1
2011 23' FB Flying Cloud
Boise , Idaho
DirecLink brake controller
I have a 23fb, and have just upgraded to 15" rims and Lt tires. I have been
pondering changing my brake controller(Curt) for the DirecLink. Reading all
the reviews on the internet the DirecLink has mostly positive reviews, but
most are from 2011 to 2013. For those of you who tow with the DirecLink,
are you still happy with your decision?
Wayne
Holmeshunter is offline   Reply With Quote
Old 05-03-2015, 02:26 PM   #2
Denis4x4's Avatar
Durango , Colorado
Absolutely! The more I use it, the more I like it. There is other info that can be displayed as well. I have another vehicle with a Prodigy II that isn't half as good.
If you don't go first class, your heirs will!
Denis4x4 is offline   Reply With Quote
Old 05-03-2015, 04:12 PM   #3
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Consider the NE version for your eventual trailer disc brake conversion
Old 05-03-2015, 04:19 PM   #4
dznf0g's Avatar
Oswego , Illinois
YES!, however since the new Gen GM truck's integrated brake controller now work with electric over hydraulic AS brakes, I am using the GM controller this year.
Tuson is a quality company too, I sent mine back for the screen getting dim, out of warranty, and they fixed it for free. They were going to charge me twenty something, IIRC, to reprogram as an NE for future ABS install....but they did that for free as well!!!
The base model works with discs....just not ABS nor sway control.
-Rich-
Old 05-04-2015, 10:49 AM   #5
Edistobob's Avatar
2013 25' Flying Cloud
Edisto Island , South Carolina
Yes, we are happy with ours. We'll be starting the second season with it soon and are still very happy with having made the change to DirecLink.
Edistobob is online now   Reply With Quote
Old 05-04-2015, 11:16 AM   #6
batman's Avatar
1964 22' Safari
modesto , California
When I changed the axle I when with disc brakes and a DirecLink electric/hydraulic actuator and DirecLink brake controller by Tuson. I also have a Tekonsha P-3 I liked just fine. However the DirecLink function is far superior especially when paired together in my experiance.
I have had mine for a little over 2 years now and love towing with it. Disc brakes are unbelievable!!
Now there are 2 things I have to add about the DirecLink Controller I do not like.
1)The screen is like a hand held CB radio mic. and attaches to the dash with a cheesy peel and stick mounting tab. Mine has failed 3 times. They send me new tabs for free (good customer service) but it sure frustrating when it falls of the dash.
2) The small color screen has clouded up and is now very difficult to see in the daylight. I have not addressed this issue with cust support yet.
-Dennis
batman is offline   Reply With Quote
Old 07-09-2015, 07:13 AM   #7
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
We are on year 5 with our Direct Link. Recently I noticed the screen going blank. I purchased the unit direct from the Airstream factory store. I called DL yesterday and they are sending me a new hand held display at no cost along with a UPS return label so I can return the old unit. So, DL has been good to me.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 07-09-2015, 07:18 AM   #8
dznf0g's Avatar
Oswego , Illinois
When I spoke with them about the screen, they were open with me about the issue. I commented that white on blue was difficult to see in direct sunlight and they were trying to source a new supplier with, maybe, black on white coloration. They believe, as I do, that interior vehicle heat is contributing to screen fade. I recommend that when parking for longer periods in high heat, that you unplug the head and put it in a cooler location. Tuson thought that was a good idea until they find a remedy.
-Rich-
Old 07-10-2015, 02:27 PM   #9
retired USA/USAF
2001 30' Excella
Well I guess that's real service. Only yesterday I spoke with Tuson regarding my display and here today a new one is delivered. Can't ask for or expect anything better than that. Thank you Tuson, you have a happy customer here.
Roger in NJ
TAC - NJ 18
Old 07-10-2015, 08:20 PM   #10
Edistobob's Avatar
I had the same sort of experience with them on our current trip. After I was on the road I realized I couldn't read the screen. One phone call and the replacement display with the return label was waiting for us at our first campground stop. Their customer service is tops.
Old 07-10-2015, 08:58 PM   #11
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The DirecLink NE we installed solved all our disc brake pump issues (Titan BrakeRite II SD) we had with the 2012 Dodge Ram 2500HD built in brake controller. The Titan was incompatible with any built in brake controller.
We have replaced the hand held display twice so far. I think the display does not like the high heat that builds up in the truck cab in the SouthWest. A cooler night and the display is faintly seen.
If I knew then what I know now, I would have gone ahead and installed the Tuson ABS pump and ABS compatible disc brakes rotors and calipers.
DirecLink Brake controller... Mexray Brakes & Brake Controllers 123 01-03-2016 08:58 AM
Direclink max braking setting dznf0g Brakes & Brake Controllers 6 08-02-2014 05:04 AM
Installing a DirecLink Brake Controller in Lexus GX-460 OrangeKid Brakes & Brake Controllers 7 04-03-2013 11:54 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
