Old 12-16-2014, 01:37 PM   #1
mje
2013 30' Flying Cloud
Did I just damage my trailer brakes?
Last night, I hitched up (NOTE: for the first time on electrical connection) and forgot to unplug the main power from AS when I plugged in trailer power cord to the truck. When I took it out of the driveway, I pushed the lever on trailer brake on my dash - nothing happens, the trailer did not engage the brakes and not slowing me down. So, did I damage the trailer brake electronics? Oh I forgot to note that AS batteries are completely drained (fried from 2 stage charger - that's an entirely separate issue that I have to deal with).
mje is offline   Reply With Quote
Old 12-16-2014, 02:56 PM   #2
SteveH's Avatar
Common Sense , Texas
If I understand correctly, you plugged the trailer connector into the truck while the trailer was still plugged into shore power?
If this is correct, this should not damage the electric brakes as I've done it frequently. Sounds like you have a different problem with the brakes. Have you double checked the wiring between the truck and the trailer?
Regards,
Steve
Old 12-16-2014, 03:03 PM   #3
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
just the English Language
timhortons is offline   Reply With Quote
Old 12-16-2014, 04:06 PM   #4
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Dial up your gain for your electric trailer brakes in your truck.
Old 12-16-2014, 04:24 PM   #5
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Agree - I don't think the shore line shouldn't cause a problem with trailer brakes. Must be a problem somewhere in the braking system. Maybe a blown fuse?
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-16-2014, 06:12 PM   #6
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Did you check the connection on the 7 pin? They get corroded, and some times the female contacts spread. Try disconnecting and reconnecting several times.
Old 12-17-2014, 01:02 PM   #7
1975 31' Sovereign
West Liberty , Kentucky
Check the wiring from the trailer that goes to the brakes. One time I did not have brakes on a slick ramp ( I had to stop and clean my drawers-not the ones in the trailer). The wires had worked loose where they connected to the brakes on the axle.
Air4563 is offline   Reply With Quote
Old 12-17-2014, 01:19 PM   #8
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
check your 7 pin from TV to AS, then check your brake controller. Its something simple.
NavyCorpsman is offline   Reply With Quote
Old 12-17-2014, 01:22 PM   #9
Gainesville , Florida
Are you plugged in upside down? Do your running lights work?
Old 12-17-2014, 01:31 PM   #10
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
OK... it might be a simple problem. So you feel comfortable... give the wheels "the sniff test" for HOT wiring. You probably do not smell a thing. Good.
You might want to get one wheel off the concrete and see if it spins easily. It will... good. It does not... then you can disregard my solution.
When we purchased our 2008 Toyota Tundra and plugged the trailer into the receiver... NO BRAKES. With the 2006 Tundra it worked fine. So... the next thing I checked was the FUSE that plugs below the dash board on the left side. It was burned out. Obviously, before we bought the truck... too. The fuse might have been a 30amp that pulls out and you just plug a good fuse into the spot. They are color coded, so no confusion.
There were actually a couple spares plugged into the circuits under the hood, and I think there was one I pulled out to use. I later bought a packet of ten fuses, that I never needed or used... but had them anyways.
I suspect this fuse in whatever vehicle you are using as a Tow Vehicle is the problem. If not... sell me the trailer as Junk and trade the tow vehicle in for a sports car. I will tow the Airstream home and figure out what to do with it.
Just kidding... but check the fuse first.
Ray Eklund is offline   Reply With Quote
Old 12-17-2014, 02:20 PM   #11
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Do the trailer brakes need good coach batteries to work, or are they powered by the truck?
Doug and Cheryl
Old 12-17-2014, 02:57 PM   #12
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Both, I think. The trailer definitely needs good coach batteries to work with the breakaway switch and for the trailer to be driven legally. That circuit is open when the pin is in the breakaway switch. I think when it is connected to the truck the brakes work of current that the truck supplies through the controller.
This problem has happened to me several times over the years and it has always been a problem with the wiring in the trailer connector.
I think the OP needs to check the brake output voltage and the ground at the 7pin on the truck and to check continuity in the brake circuit on the trailer.
Seems like the controller should have some sort of indicating light or gauge to tell if the brakes are hooked up and if the controller is outputting current to them. My cheap controller has a LED that changes color to show that information. If I had been smart enough to read it I would have saved me a 200 mile round trip back to Anchorage to have the controller checked the first time the wire in the connector broke.
Old 12-17-2014, 05:11 PM   #13
Moflash's Avatar
Brakes are powered by tow vehicle only
Old 12-17-2014, 05:31 PM   #14
Not the breakaway switch. Jim
What I did not know about trailer brakes lsbrodsky Brakes & Brake Controllers 16 08-28-2013 06:23 AM
I did look I really did bennu36 Sprinter and B-van Forum 11 08-12-2013 01:01 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
The dent that did no damage! RichardT Our Community 32 11-22-2006 01:59 PM
