Old 12-17-2014, 05:56 PM   #15
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Did your truck come with a towing package, and have you towed with it before?
Mine supposedly came with a full towing package including brake controller - but did not work, I forget if it was brakes, running lights or whatever but I distinctly recall something was inoperative - the truck was brand new.
Took it back to the dealer and it turned out there were extra fuses that had to be installed or wires connected, they didn't give me exact details - in any event that was the problem!
You can get 7 pin socket testers to stick in the truck socket - they have LED lights to confirm power on the various pins. Likely Harbor Freight would have them in the U.S.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-17-2014, 07:33 PM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Under normal circumstances the brakes are powered by the TV.
BUT!!! The breakaway switch applies the brakes if you lose the coach. This requires that it be powered by the coach battery. Usually by a non fused wire.
Old 12-17-2014, 10:13 PM   #17
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Replace batteries BEFORE towing...
Is the 'breakaway' switch pin/plunger installed? If pulled, it would engage brakes and drain batteries in fairly short order.
You must figure out the wiring of the 7way... oh, and BTW, did this 'work' before?
Peace and Blessings..
Channing
WBCCI# 30676
What I did not know about trailer brakes lsbrodsky Brakes & Brake Controllers 16 08-28-2013 06:23 AM
I did look I really did bennu36 Sprinter and B-van Forum 11 08-12-2013 01:01 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
The dent that did no damage! RichardT Our Community 32 11-22-2006 01:59 PM
