Old 09-20-2015, 06:38 PM   #1
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Silver City , New Mexico
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Dexter Hydraulic Brake & GMC truck...
I'm in the process of buying a 2008 Classic Limited 34' with Dexter electric hydraulic brakes. When we hooked it up to my 2015 GMC Sierra 2500HD (factory equipped brake controller), the Dexter unit kept powering up. Did the same thing on Denali and on a Ford (both with add-on controllers).
Question, is this a compatibility issue with the GMC, et al or a wiring problem with the Dexter unit? The hydraulic reservoir is filled with fluid and there are no apparent leaks. Anyone else experienced this problem?
TIA
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 09-20-2015, 09:23 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Don't know... Do you have a battery in the AS? Does
The "breakaway" Switch cause them to activate?
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-21-2015, 05:57 AM   #3
E Pluribus Aluminus
Jaxon's Avatar
1967 22' Safari
2005 30' Classic
Yes, 2 lifeline batteries and yes, the breakaway switch does cause it to activate. It's as if once hooked up, current is constantly running activating the brakes. It's specific only to this trailer as we hooked my truck to another 34' with the same Dexter unit and did not have the problem...
Bill & Kim
Old 09-22-2015, 12:11 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sounds like the umbilical needs to be checked. I'd wager there is a 'short' somewhere inside where the 12v feed is going to the Dexter device. another possibility is a faulty Dexter control board. It could be that the 'sample' voltage sent by the TV to 'sense' the trailer brakes are connected is causing the Dexter to energize.
Channing
WBCCI# 30676
Old 09-22-2015, 01:16 PM   #5
E Pluribus Aluminus
Jaxon's Avatar
1967 22' Safari
2005 30' Classic
This sounds the most reasonable as we have tried three different vehicles thathave the same problem as mine. My truck works fine with another 34' with the same Dexter actuator. When I tested the voltage on the "problem" trailer, I got no voltage from any of the pins. In the other 34', I got 13.7 volts from the battery pin. Seems to narrow it down to the cord or board. Hopefully not defective units...
Thanks, CWF!
Old 09-22-2015, 01:50 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Just curious.. is the battery switch in 'store' mode?
The umbilical connection box is behind the Gaucho in our 34... I would not overlook possibility something got chewed up..
Channing
WBCCI# 30676
Old 09-22-2015, 02:12 PM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
OK dumb question and minor hijack - I have an 2012 Eddie Bauer and just got a new to me 2013 GMC Sierra with a built in brake controller. I went with "plug and play" on my first short tow last weekend. Didn't get any infamous Hensley "bump" and brakes appeared to be fine. And the EB doesn't have hydraulic brakes. Do I need to do anything more than check that the brake lights on the trailer DO come on when I'm hooked up, and that I can adjust them to be a bit grabby, then back off one click?
Thanks in advance, Paula
Old 09-22-2015, 02:27 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Miss Paula,
On our 2012 truck, when I plug in the umbilical, then power on the truck, I look at the Driver Information Center (instrument panel) and I will see, "Trailer connected".
Next I press the + or - on the controller and on our 34' I set it to 5.5. At that point the brakes seem best balanced and neither 'push' or 'pull' the Truck when trying to stop.
Next, when ready to shove off, I will let the rig roll a couple of feet then push slowly on the 'slider' to ensure the TRAILER brakes engage and will stop the truck. If it won't stop the truck, then I increase the number above 5.5.. when towing, as I apply the brakes, I will lower the number and do some 'test' stops and adjust as above where the trailer braking keeps the truck from being 'pushed' or 'pulled' when stopping. Once I have this working, I try from higher speed... to a full stop.... a couple times...
Does this make sense?
Channing
WBCCI# 30676
Old 09-22-2015, 09:22 PM   #9
E Pluribus Aluminus
Jaxon's Avatar
1967 22' Safari
2005 30' Classic
We tried both use & store... And no chewed up wiring either. Finally fixed the problem - actually two fixes. We found the the black lead from the umbilical ended at the Dexter distribution box so we moved it to the bus bar- got lights and voltage. Also wired a brake magnet type device to the blue lead on the actuator and we now have brakes. Have no idea why it was wired the othe way. Time for a drink...
Paula, ditto Channing's advice. So simple it's delightful!
Bill & Kim
Old 09-23-2015, 03:09 AM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Stop by Round Rock sometime!
Wiring in a "load" like the magnet probably in the Dexter install docs. This load provides resistance to tell the truck trailer brake system "hey, I am here"!
Channing
WBCCI# 30676
Old 09-23-2015, 06:43 AM   #11
E Pluribus Aluminus
Jaxon's Avatar
1967 22' Safari
2005 30' Classic
You bet, Channing! And thanks for your input.
Bill & Kim
What Brake Controller Are You Using On Hydraulic Brake Classics? KJRitchie 2006 - 2010 Classic (all lengths) 30 09-25-2014 01:03 PM
2004 GMC Sierra 2500 HD 4WD 4DR Truck yankee5 Airstream Classifieds 0 05-17-2014 09:02 AM
2004 GMC Sierra 2500 HD 4WD 4DR Truck yankee5 Airstream Classifieds 1 02-07-2014 10:45 AM
Connecting Hydraulic Disk Brakes on 2008 GMC Savana mcpowell Brakes & Brake Controllers 1 10-21-2013 06:00 PM
Dexter #11 hydraulic vs Alcola rims erock53 Wheels, Hubs & Bearings 4 10-19-2007 07:40 AM
