Old 08-12-2010, 07:43 PM   #1
2006 30' Classic
Milton , Florida
Dexter E/H Actuator to replace ActiBrake Actuator
I would greatly appreciate hearing from owners that have replaced Actibrake actuators with Dexter E/H actuators, or have installed Dexter actuators for any reason. Information on the exact Dexter model number used, ease of installation, if you did it yourself, etc. Of special interest is how well the Dexter actuator worked with a Ford ITBC.
My Actibrake unit stopped working recently, and I am giving consideration to replacing it with a Dexter unit. Our trailer is a 2006 model year Classic, 30 ft., pulled by a 2010 Ford F-250 with the ITBC.
F. A. Meloy
nickmeloy is offline   Reply With Quote
Old 08-18-2010, 11:05 AM   #2
F. A. Meloy
Most of the owners that required a replacement went with the Carlisle actuator.
Old 08-20-2010, 07:40 AM   #3
WK57ABF's Avatar
2007 25' Classic
kendal , cumbria, UK
nickmeloy,
According to the Carlisle web site, their actuator is not compatible with your truck.
The Titan Brake Rite II SD is compatible with the adapter module.
The Dexter DX1600 is compatible with the 2008-2010 Super Duty Ford ITBC.
I'll be fitting the Dexter unit, at my own cost, if Airstream don't replace the Actibrake unit currently fitted and subject to a recall. Although it works at the moment, I have no faith in it and it probably wont work in the future.
Our truck is an 2008 F350 6.4 Super Duty.
John in the UK
WK57ABF is offline   Reply With Quote
Old 08-20-2010, 03:15 PM   #4
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I have a 2010 F-250 with ITBC and my Carlisle actuator works just fine.
4RXLA is offline   Reply With Quote
Old 09-18-2010, 04:04 PM   #5
2006 30' Classic
Milton , Florida
Dexter 1600 psi Actuator Installation
I removed the Actibrake actuator last weekend, cleaned and painted the metal box at the front of the trailer (2006 model, 30 ft. Classic with hydraulic disc brakes), traced and cleaned up the wireing, and installed the Dexter actuator. The unit was tested with the breakway switch and it performed as specified. The unit was confirmed to work with the manual slide when connected to the truck (2010 F-250 with Ford's ITBC), which was then used to bleed the brakes.
I road tested the trailer today, and the brake operation seems to be more agressive than when using the previous actuator (Actibrake) at the same gain setting (7.5) on the ITBC.
I would appreciate hearing from other Ford ITBCs controlling a Dexter actuator as to the gain setting that they have found to be satisfactory on this size trailer (30 ft. Classic).
Nick Meloy
Old 09-18-2010, 05:31 PM   #6
4RXLA's Avatar
Images: 33
Nick, for what it is worth, I have my ITBC set to 7.5 also for my Carlisle actuator.
Old 09-18-2010, 07:18 PM   #7
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
F. A. Meloy
If you can have a dealer do the "Recall" it could save you big $$.
There is a problem with the brake fluid getting on the electronics. This causes the actuator to fail.
BTW I went with the Carlisle unit. It is supposed to work with my 2006 F-250 with Tow Command.
Michelle TAC MT-0
Sarah, Snowball
Old 09-18-2010, 10:12 PM   #8
Is the Carlisle actuator a 1600 or 1200?
pattonsr is offline   Reply With Quote
Old 09-18-2010, 11:48 PM   #9
4RXLA's Avatar
Images: 33
1600
Old 09-19-2010, 09:28 AM   #10
Keymar , Maryland
1600 for disk, 1200 for drum.
Michelle TAC MT-0
Sarah, Snowball
Old 09-19-2010, 05:23 PM   #11
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Actibarke 1976 Airstream
I installed the Kodiak disk brakes and the Actibrake actuator on my 1976 A/S a little over 2 years ago and I have not had any problems, yet. Is the Actibarke failure more frequest with the newer factory installed Airstreams or does the failure occur in the retro fit installations as well. Thanks
Don
adonh is offline   Reply With Quote
Old 09-19-2010, 06:11 PM   #12
Don
Don.
It appears that the bulk of the problems, was with the latest Actibrake actuator, that's housed in a plastic jacket.
Old 09-20-2010, 07:47 AM   #13
adonh's Avatar
1976 31' Sovereign
Andy I bought the Disk brakes and Actibrake from you at the end of 2008. It's gray about the size of a shoebox. Would that be it.
Don
Old 09-20-2010, 09:34 AM   #14
Don
Don.
This is a photo of the original Actibrake, that's OK.
Titan Brakerite or Dexter actuator? Canlib Brakes & Brake Controllers 0 07-18-2010 04:42 PM
Colonial Airstream Dexter Actuator Install craftsman Brakes & Brake Controllers 0 06-18-2010 11:23 AM
The New Dexter Actuator thecatsandi Brakes & Brake Controllers 1 04-13-2010 12:53 PM
Dexter actuator ? richnritab Brakes & Brake Controllers 20 07-23-2006 12:25 PM
Dexter E/H Actuator Buttercup Brakes & Brake Controllers 17 05-25-2005 09:00 AM
