Old 10-21-2014, 09:48 PM   #29
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
How is the 12v TV/trailer wire connected to your Dexter. Mine seems to be connected directly to the Dexter unit. The side effect is my TV is not charging my batteries.
The trailer/TV comes up into the trailer. The black wire is separated and another black wire is added for length with a butt connector. That wire goes back out the same hole to the outside and is part of other wires in a plastid loom and it seems to come out in hydraulic actuator compartment.
Kelvin
KJRitchie is online now   Reply With Quote
Old 10-21-2014, 10:01 PM   #30
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Originally Posted by KJRitchie View Post
For some reason the AS dealer when they installed my Dexter put what looks like a trailer brake magnet on the blue line of the Dexter. I take that everyone posting in this thread doesn't have such a thing?
Should I disconnect it and see what happens?
Kelvin
If your tow vehicle has an integrated controller like my Silverado, it is necessary to make the TV think there are drum brakes on the trailer for the controller to know there is a trailer back there. I have two brake magnets mounted on the box behind the propane tanks to make my Silverado think there are drum brakes on the trailer. Works fine. I would leave the magnets hooked up if I were you. I wrote an article some time back in Airstream Life magazine on using magnets with GM integrated controllers.
John W. Irwin
WBCCI #9632
Old 10-21-2014, 10:06 PM   #31
KJRitchie's Avatar
2008 25' Classic
My TV is a Tundra and I use a Prodigy 2. It is set for E/H mode. Do I still need this magnet?
Kelvin
Old 10-21-2014, 10:21 PM   #32
Pahaska's Avatar
Hays County , Texas
Kelvin
Probably not. OTOH, it doesn't hurt anything and if for any reason the trailer needs to be towed by another TV, it may permit the controller in that TV to work where it would not work otherwise. For instance, without the magnet, I could not tow it with my 2013 Silverado using the built-in controller.
John W. Irwin
WBCCI #9632
Old 10-22-2014, 08:58 AM   #33
KJRitchie's Avatar
2008 25' Classic
OK, I'll leave it alone then.
Thanks for the advise.
Kelvin
Titan Brakerite or Dexter actuator? Canlib Brakes & Brake Controllers 0 07-18-2010 04:42 PM
Colonial Airstream Dexter Actuator Install craftsman Brakes & Brake Controllers 0 06-18-2010 11:23 AM
The New Dexter Actuator thecatsandi Brakes & Brake Controllers 1 04-13-2010 12:53 PM
Dexter actuator ? richnritab Brakes & Brake Controllers 20 07-23-2006 12:25 PM
Dexter E/H Actuator Buttercup Brakes & Brake Controllers 17 05-25-2005 09:00 AM
