Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 03-22-2007, 07:13 PM   #1
Pecos Pete
Profile:  2007 34' Classic
Pecos , New Mexico
Dexter disc brake failure - stranded in Medford
We are on the road and stuck in Medford OR. Our disc brakes have sprung a fluid leak in the wheel well on one side. The nearest AS dealer is nearly three hours away. Never had this problem before - who can work on these brakes?? I don't feel comfortable driving through the mountains for three hours without trailer brakes on a 34' classic.
Can anyone give me some advice? Thanks!
Pecos Pete is offline   Reply With Quote
Old 03-22-2007, 07:19 PM   #2
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Pecos,
Is there any way for you to isolate the leak that will allow you to use the remainder of your brakes? At least this will give you some braking so you can get to a repair shop.
Also, have you tried to find acommercial trailer repair place that might be able to do a temporary fix? I know that there is a pretty good Airstream dealer in Eugene.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 03-22-2007, 07:20 PM   #3
markdoane
Profile:  , Minnesota
Images: 59
Try a horse trailer shop.
Recreational Vehicles ;RV Sales;Southern Oregon RV Dealer;Siskiyou RV World RV Trailers Motorhomes and Fifth Wheels Sales & Service
Non-contributing deadbeat.
Old 03-22-2007, 08:07 PM   #4
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
any auto shop should be able to repair a hydraulic brake leak. The actuator is the only difference between it and any other brakeing sytem. Best of luck
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 03-22-2007, 08:42 PM   #5
Pecos Pete
Pecos , New Mexico
Thanks for the advice guys! I will spend the night and try an RV repair shop or auto repair shop in the morning. Hopefully, will be on th road north again by afternoon.
Pecos Pete
Old 03-22-2007, 08:51 PM   #6
2airishuman
2airishuman's Avatar
Profile:
hi pete, any idea where the leak originates...
is it a fitting or connection to the caliper, or inside the caliper?
i've heard of leaks inside the dexter caliper as fitted on a/s...
also, hookedonclassics had a leak from a rub/friction on a steel line that was...
to close to a tire? happened very early in ownership or just after delivery...
take photos AND document the issue...
unless you snagged a line on debris you should have warranty coverage...
i'd even consider having a mechanic house call....
if there isn't a shop close...
keep us informed.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 03-22-2007, 10:10 PM   #7
Pecos Pete
Pecos , New Mexico
I have looked at the situation really good before it got dark tonight. I can't find the leak, but know it is pretty bad. I filled the reservior at a truck stop and tested the brakes, only to find the fluid all over the ground in the twenty or so feet I pulled up and tested the brakes. I only had a few miles to go until my overnight stop, so I drove on - with white knuckles. There is an RV repair shop - not AS just down the road. I am going to call them first thing in the am to see if I can get in to have a look. If it is something other than a line or fitting, is it possible to have them bypass only that brake, leaving the other two on that side and the three on the the street side in order to get us down the road and to an AS dealer in Eugene? The trailer is new, so warranty should cover the repair, if needed. I would prefer AS to do the repair if it something major.
I really appreciate your help. This is what the forum is for, at least in my humble opinion!
Pecos Pete
Old 07-01-2007, 10:34 PM   #8
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Pete.... How did you get this resolved?
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Dexter axles - What I wanted & what I got LI Pets Axles 18 02-21-2007 01:53 AM
disc brakes overlander Brakes & Brake Controllers 10 01-25-2003 11:29 PM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
